dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.toolbars.draw"); dojo.require("esri.toolbars.edit"); dojo.require("esri.layers.FeatureLayer"); dojo.require("esri.dijit.editing.TemplatePicker"); dojo.require("esri.dijit.AttributeInspector"); var map; function init() { //This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic //for details on setting up a proxy page. esri.config.defaults.io.proxyUrl = "/proxy"; esri.config.defaults.io.alwaysUseProxy = false; map = new esri.Map("map", { basemap: "streets", center: [-83.243, 42.584], zoom: 15 }); dojo.connect(map, "onLayersAddResult", initEditing); var pointLayer = new esri.layers.FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Military/FeatureServer/6", { mode: esri.layers.FeatureLayer.MODE_SNAPSHOT, outFields: ["*"] }); var lineLayer = new esri.layers.FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Military/FeatureServer/8", { mode: esri.layers.FeatureLayer.MODE_SNAPSHOT, outFields: ["*"] }); var polygonLayer = new esri.layers.FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Military/FeatureServer/9", { mode: esri.layers.FeatureLayer.MODE_SNAPSHOT, outFields: ["*"] }); map.addLayers([pointLayer,lineLayer,polygonLayer]); } function initEditing(results) { var map = this; var layers = dojo.map(results, function(result) { return result.layer; }); //display read-only info window when user clicks on feature var query = new esri.tasks.Query(); dojo.forEach(layers, function(layer) { dojo.connect(layer, "onClick", function(evt) { if (map.infoWindow.isShowing) { map.infoWindow.hide(); } var layerInfos = [{ 'featureLayer': layer, 'isEditable': false, 'showDeleteButton':false }] var attInspector = new esri.dijit.AttributeInspector({ layerInfos: layerInfos }, dojo.create("div")); query.objectIds = [evt.graphic.attributes.objectid]; layer.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function(features) { map.infoWindow.setTitle(""); map.infoWindow.setContent(attInspector.domNode); map.infoWindow.resize(310, 165); map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint)); }); }); }); var templatePicker = new esri.dijit.editing.TemplatePicker({ featureLayers: layers, rows: 'auto', columns: 'auto', grouping: true }, "templatePickerDiv"); templatePicker.startup(); var drawToolbar = new esri.toolbars.Draw(map); var selectedTemplate; dojo.connect(templatePicker, "onSelectionChange", function() { selectedTemplate = templatePicker.getSelected(); if (selectedTemplate) { switch (selectedTemplate.featureLayer.geometryType) { case "esriGeometryPoint": drawToolbar.activate(esri.toolbars.Draw.POINT); break; case "esriGeometryPolyline": selectedTemplate.template.drawingTool === 'esriFeatureEditToolFreehand' ? drawToolbar.activate(esri.toolbars.Draw.FREEHAND_POLYLINE) : drawToolbar.activate(esri.toolbars.Draw.POLYLINE); break; case "esriGeometryPolygon": selectedTemplate.template.drawingTool === 'esriFeatureEditToolFreehand' ? drawToolbar.activate(esri.toolbars.Draw.FREEHAND_POLYGON) : drawToolbar.activate(esri.toolbars.Draw.POLYGON); break; } } }); dojo.connect(drawToolbar, "onDrawEnd", function(geometry) { //display the editable info window for newly created features if (map.infoWindow.isShowing) { map.infoWindow.hide(); } drawToolbar.deactivate(); var fieldAttributes = layerFieldToAttributes(selectedTemplate.featureLayer.fields); var newAttributes = dojo.mixin(fieldAttributes, selectedTemplate.template.prototype.attributes); var newGraphic = new esri.Graphic(geometry, null, newAttributes); var layerInfos = [{ 'featureLayer': selectedTemplate.featureLayer, 'isEditable': true }]; var attInspector = new esri.dijit.AttributeInspector({ layerInfos: layerInfos }, dojo.create("div")); selectedTemplate.featureLayer.applyEdits([newGraphic], null, null, function() { var screenPoint = map.toScreen(getInfoWindowPositionPoint(newGraphic)); map.infoWindow.setContent(attInspector.domNode); map.infoWindow.resize(325, 185); map.infoWindow.show(screenPoint, map.getInfoWindowAnchor(screenPoint)); templatePicker.clearSelection(); }); dojo.connect(attInspector, "onAttributeChange", function(feature, fieldName, newFieldValue) { feature.attributes[fieldName] = newFieldValue; feature.getLayer().applyEdits(null, [feature], null); }); dojo.connect(attInspector, "onDelete", function(feature) { feature.getLayer().applyEdits(null, null, [feature]); map.infoWindow.hide(); }); }); } function getInfoWindowPositionPoint(feature) { var point; switch (feature.getLayer().geometryType) { case "esriGeometryPoint": point = feature.geometry; break; case "esriGeometryPolyline": var pathLength = feature.geometry.paths[0].length; point = feature.geometry.getPoint(0, Math.ceil(pathLength / 2)); break; case "esriGeometryPolygon": point = feature.geometry.getExtent().getCenter(); break; } return point; } function layerFieldToAttributes(fields) { var attributes = {}; dojo.forEach(fields, function(field) { attributes[field.name] = null; }); return attributes; }
