I'm having problems to set the proxy for my application!
My current setup:
- ArcGIS Server 10.4 on 'server.virtual.private' or '192.168.210.100'
- Proxy .NET running with IIS 8.5 on 'server.virtual.private' (same machine than ArcGIS Server 10.4)
- Application with Javascript API 3.16 on 'host-vm' or '192.168.210.1' (with browsersync.io)
Installed the proxy from GitHub
Put the .NET version on a inetpub\wwwroot subfolder, created a app, etc...
Then, I tested the proxy (according with the README.md):
"Test that the proxy is installed and available":
http://server.virtual.private/DotNet/proxy.ashx?ping!
Got a valid response:
{ "Proxy Version": "1.1.0", "Configuration File": "OK", "Log File": "Not Exist/Readable"}"Test that the proxy is able to forward requests directly in the browser using":
http://server.virtual.private/esri_proxy/proxy.ashx?http://server.virtual.private/arcgis/rest/services/teste/TEST_SERVICE/FeatureServer?f=json
"currentVersion":10.4,
"serviceDescription":"TEST_SERVICE",
"hasVersionedData":false,
"supportsDisconnectedEditing":false,
"syncEnabled":false,
"supportedQueryFormats":"JSON, AMF",
"maxRecordCount":1000,
"capabilities":"Create,Delete,Query,Update,Uploads,Editing",
"description":"",
"copyrightText":"",
"spatialReference":{
"wkid":102100,
"latestWkid":3857
"initialExtent":{
"xmin":-5373925.95008382,
"ymin":-1779327.897638279,
"xmax":-5367538.895643042,
"ymax":-1776174.0579972658,
"wkid":102100,
"latestWkid":3857
"fullExtent":{
"xmin":-5371483.1645,
"ymin":-1779695.3658000007,
"xmax":-5368931.5394,
"ymax":-1776737.2322000004,
"wkid":102100,
"latestWkid":3857
"allowGeometryUpdates":true,
"supportsApplyEditsWithGlobalIds":false,
"units":"esriMeters",
"documentInfo":{
"Title":"",
"Author":"",
"Comments":"",
"Subject":"",
"Category":"",
"Keywords":"TEST_SERVICE"
"layers":[
"id":0,
"name":"TEST_SERVICE"
"tables":[
"enableZDefaults":false
}So, the proxy appear to be OK!
Then, I edited the proxy.config file, with this content (this is for test development):
<?xml version="1.0" encoding="utf-8" ?>
<ProxyConfig allowedReferers="*" mustMatch="false">
<serverUrls>
<serverUrl url="http://server.virtual.private" matchAll="true" username="siteadmin" password="secret" />
</serverUrls>
</ProxyConfig>
Then, according with README.md, and document on Using the proxy | Guide | ArcGIS API for JavaScript I must put the URL of the proxy on my javascript application.
I put the following lines on top of main file of application:
esriConfig.defaults.io.proxyUrl = 'http://server.virtual.private/DotNet/proxy.ashx';
esriConfig.defaults.io.alwaysUseProxy = false;
Tested my application and got a 500 response when asked for a Feature Layer.
"XMLHttpRequest cannot load http://server.virtual.private/DotNetProxy/proxy.ashx?http://server.virtual.private/arcgis/rest/services/teste/TEST_SERVICE/FeatureServer?f=json. Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested source. Origin 'http://192.168.210.1:8080' is therefore not allowed access.".
So, I got a CORS! but according with the documentation on Using the proxy | Guide | ArcGIS API for JavaScript:
"ArcGIS Server 10.1 supports CORS out of the box." |
OK, I have some problems now!!
In same documentation:
"For earlier versions, an administrator can add CORS support. Visit enable-cors.org for detailed instructions" |
Let's try anyway!
Modified the web.config file on proxy application on IIS (from lines 07 to 15).
<?xml version="1.0"?>
<configuration>
<system.web>
<compilation debug="false" targetFramework="4.0"/>
</system.web>
<system.webServer>
<httpProtocol>
<customHeaders>
<add name="Access-Control-Allow-Origin" value="*" />
<add name="Access-Control-Allow-Headers" value="*" />
<add name="Access-Control-Allow-Methods" value="*" />
</customHeaders>
</httpProtocol>
</system.webServer>
<system.diagnostics>
<switches>
<add name="TraceLevelSwitch" value="Info" />
</switches>
<trace autoflush="true" indentsize="4">
<listeners>
<add name="agsProxyLogListener" type="System.Diagnostics.TextWriterTraceListener"
initializeData="C:\Temp\Shared\proxy_logs\auth_proxy.log" />
<remove name="Default" />
</listeners>
</trace>
</system.diagnostics>
</configuration>
Now, I get a new error!
"XMLHttpRequest cannot load http://server.virtual.private/DotNetProxy/proxy.ashx?http://server.virtual.private/arcgis/rest/services/teste/TEST_SERVICE/FeatureServer?f=json. Request header field X-Requested-With is not allowed by Access-Control-Allow-Headers in preflight response.".
So, what's the correct way to configure the proxy? Because I do everything that was on documents, and got errors.
