You can use the Fishnet tool to make a grid that would be the same extent as your grid. Alternatively, if your grid extent isn't large, then just make a new line shapefile (or other feature class) and manually draw the lines that intersect the points. You may be able to draw in the sub-divisional lines after this... ?
