I'm having the same issue with my output file (a txt file in my case) getting outputted to the wrong folder in the directory path. I have tried to follow Matthew's solution above to incorporate the "/" after the GetParameter, but I end up with syntax errors. Could someone alter his code to show me where the "/" should be placed? Thanks.
Without seeing the code and error it's hard to say. Are you putting "/" for the rest of the path? If you use "\" you need to add the r at the beginning of the path."Y:/folder1/folder2/folder3/PARAMETER INPUT" or r"Y:\folder1\folder2\folder3\PARAMETER INPUT" . Is your output setting of the parameter a text?
It would be better to use the os.path.join to create the path to the output file.
Example:
import os my_folder = r"C:\aFolder\aSubFolder" my_filename = "someFileName.ext" print os.path.join(my_folder, my_filename)
... will yield this:
C:\aFolder\aSubFolder\someFileName.ext
And you can even do this:
import os my_folder = r"C:\aFolder\aSubFolder" my_filename = "someFileName.ext" print os.path.join(my_folder, "anotherSubFolder", my_filename)
... which will yield this:
C:\aFolder\aSubFolder\anotherSubFolder\someFileName.ext
Thank you Matthew and Xander.
Using the os.path.join worked like a charm.
