protected function MainMap_mapClickHandler(event:MapMouseEvent):void { var identifyParams:IdentifyParameters = new IdentifyParameters(); var clickGraphic:Graphic = new Graphic(event.mapPoint, clickPointSymbol); identifyParams.returnGeometry = true; identifyParams.tolerance = 5; identifyParams.width = MainMap.width; identifyParams.height = MainMap.height; identifyParams.geometry = event.mapPoint; identifyParams.mapExtent = MainMap.extent; identifyParams.spatialReference = MainMap.spatialReference; identifyParams.layerIds = layerLIS.visibleLayers.source; //replace this with your layerID identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL; clickGraphicsLayer.clear(); MainMap.infoWindow.hide(); graphicsLayer.clear(); cursorManager.setBusyCursor(); identifyTask.url = layerLIS.url; //replace this with your layer URL identifyTask.execute(identifyParams, new AsyncResponder(resultFunction, faultFunction, clickGraphic)); function resultFunction(results:Array, clickGraphic:Graphic):void { var myInfoRenderer:InfoRenderer = new InfoRenderer; var mapPoint:MapPoint = MapPoint(clickGraphic.geometry); var point:Point = MainMap.toScreen(mapPoint); if (results && results.length > 0) { var oldLayer:Number = -1; var resultsArray:Array = []; var result:IdentifyResult; var resultGraphic:Graphic; var tab:TabNavigator = new TabNavigator(); var newVBox:VBox = new VBox; var newVBoxDG:VBox = new VBox; var newText:Text = new Text; var newDG:DataGrid = new DataGrid; var graphic:Graphic; clickGraphicsLayer.add(clickGraphic); result = results[0]; oldLayer = result.layerId; resultsArray.push(result.feature.attributes); newText = new Text; newText.text = result.layerName; graphic = result.feature; graphic.alpha = 0.3; graphicsLayer.add(graphic); tab.width = 400; tab.height = 230; // for (var i:int = 1; i < results.length; i++) // { // result = results; // graphic = new Graphic; // graphic = result.feature; // graphic.alpha = 0.3; // graphicsLayer.add(graphic); // if (result.layerId == oldLayer) // { // resultsArray.push(result.feature.attributes); // } // else // { // newDG = new DataGrid; // newVBox = new VBox; // newDG.dataProvider = resultsArray; // // newDG.addEventListener(ListEvent.ITEM_CLICK, newDG_ItemRollOver, false, 0, true); // newDG.addEventListener(ListEvent.ITEM_ROLL_OUT, newDG_ItemRollOut, false, 0 ,true); // newDG.addEventListener(ListEvent.ITEM_ROLL_OVER, newDG_ItemRollOver, false, 0, true); // // newVBox.addElement(newText); // newVBox.addElement(newDG); // newVBox.label = oldLayer.toString(); // newVBox.label = oldLayer.toString(); // tab.addElement(newVBox); // myInfoRenderer.addElement(tab); // // newText = new Text; // newText.text = result.layerName; // resultsArray = []; // resultsArray.push(result.feature.attributes); // } // oldLayer = result.layerId; // } newVBox = new VBox; newVBoxDG = new VBox; newDG = new DataGrid; newDG.addEventListener(ListEvent.ITEM_CLICK, newDG_ItemRollOver, false, 0, true); newDG.addEventListener(ListEvent.ITEM_ROLL_OUT, newDG_ItemRollOut, false, 0, true); newDG.addEventListener(ListEvent.ITEM_ROLL_OVER, newDG_ItemRollOver, false, 0, true); newVBox.addElement(newText); newDG.dataProvider = resultsArray; newVBox.addElement(newDG); newVBox.label = oldLayer.toString(); tab.addElement(newVBox); myInfoRenderer.addElement(tab); cursorManager.removeBusyCursor(); MainMap.infoWindow.content = myInfoRenderer; MainMap.infoWindow.label = "Results"; MainMap.infoWindow.show(MainMap.toMap(point)); MainMap.infoWindow.addEventListener(Event.CLOSE, infoWindow_Close, false, 0, true); } } } protected function newDG_ItemRollOut(event:ListEvent):void { graphicLayer.clear(); } protected function newDG_ItemRollOver(event:ListEvent):void { var highlightedGraphic:Graphic = findGraphicByAttribute(event.itemRenderer.data); var glowFill:SimpleFillSymbol = new SimpleFillSymbol; var glower:AnimateFilter = new AnimateFilter(highlightedGraphic,glow); glower.motionPaths = kf; glower.duration = 500; glower.play(); } protected function faultFunction(error:Object, token:Object = null):void { cursorManager.removeBusyCursor(); Alert.show(error.toString()); } protected function findGraphicByAttribute(attributes:Object):Graphic { for each (var graphic:Graphic in graphicsLayer.graphicProvider) { if (graphic.attributes == attributes) { return graphic; } } return null; }
