public class MarkupModel : Draw { #region DrawCircle private GraphicsLayer _circleDrawingLayer; private MapPoint _circleCenter; public void StartDrawCircle() { //end any previous circle drawing EndDrawCircle(); if (_circleDrawingLayer == null) _circleDrawingLayer = new GraphicsLayer(); Map.Layers.Add(_circleDrawingLayer); Map.MouseLeftButtonDown += Map_MouseLeftButtonDown; Map.MouseLeftButtonUp += Map_MouseLeftButtonUp; Map.MouseMove += Map_MouseMove; } public void EndDrawCircle() { Map.Layers.Remove(_circleDrawingLayer); Map.MouseLeftButtonDown -= Map_MouseLeftButtonDown; Map.MouseMove -= Map_MouseMove; Map.MouseLeftButtonUp -= Map_MouseLeftButtonUp; } public Graphic CreateCircle(MapPoint center, double radius) { int numPoints = 50; //make sure the radius is a positive number radius = Math.Abs(radius); PointCollection ring = new PointCollection(); // 2PI = 360 degrees, +1 so that the end points meet for (double i = 0; i < numPoints + 1; i++) { double theta = Math.PI * (i / (numPoints / 2)); var vertexLat = center.Y + (radius * Math.Sin(theta)); var vertexLng = center.X + (radius * Math.Cos(theta)); var point = new MapPoint(vertexLng, vertexLat); ring.Add(point); } return new Graphic() { Geometry = new Polygon() { Rings = new System.Collections.ObjectModel.ObservableCollection<PointCollection>() { ring } }, Symbol = base.FillSymbol }; } #region Circle Event Handlers void Map_MouseLeftButtonDown(object sender, MouseButtonEventArgs e) { _circleCenter = Map.ScreenToMap(e.GetPosition(Map)); e.Handled = true; //need to do this or the map will allow drag } void Map_MouseMove(object sender, MouseEventArgs e) { if (_circleCenter == null) return; var radiusPoint = Map.ScreenToMap(e.GetPosition(Map)); if (radiusPoint != null) { //generate new circle points var radius = _circleCenter.DistanceTo(radiusPoint); var graphic = CreateCircle(_circleCenter, radius); //don't replace the graphic each time because it will lead to flickering, just replace geometry if (_circleDrawingLayer.Graphics.Count > 0) _circleDrawingLayer.Graphics[0].Geometry = graphic.Geometry; else _circleDrawingLayer.Graphics.Add(graphic); } } void Map_MouseLeftButtonUp(object sender, MouseButtonEventArgs e) { _circleCenter = null; if (_circleDrawingLayer == null || _circleDrawingLayer.Graphics.Count == 0) return; //only call the completed event when the polygon valid var polyGraphic = _circleDrawingLayer.Graphics.FirstOrDefault(); if (polyGraphic != null && polyGraphic.Geometry.Extent.Width > 0) { DrawMode = ESRI.ArcGIS.Client.DrawMode.Polygon; //set the draw mode to eventing will work var poly = polyGraphic.Geometry as ESRI.ArcGIS.Client.Geometry.Polygon; foreach (var point in poly.Rings[0]) { AddVertex(point); } CompleteDraw(); DrawMode = ESRI.ArcGIS.Client.DrawMode.None; //turn off the draw mode, it never happened } _circleDrawingLayer.ClearGraphics(); } #endregion Circle Event Handlers #endregion DrawCircle }
public static double DistanceTo(this MapPoint point1, MapPoint point2) { var a = (double)(point2.X - point1.X); var b = (double)(point2.Y - point1.Y); return Math.Sqrt(a * a + b * b); }
