Your reply was very helpful , thank you so much , how do i make a distinguish infoTemplate for each point ?
<!doctype html> <html lang="en"> <head> <meta charset="utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title></title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/esri/dijit/css/Popup.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{ margin: 0; padding: 0; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); var map; function init() { var initExtent = new esri.geometry.Extent({"xmin":-14052134,"ymin":5562249,"xmax":-13179529,"ymax":5897349,"spatialReference":{"wkid":102100}}); map = new esri.Map("map",{extent:initExtent}); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); dojo.connect(map, 'onLoad', function() { dojo.connect(dijit.byId('map'), 'resize', map, map.resize); var points = { "points": [[-122.63,45.51],[-122.56,45.51],[-122.56,45.55],[-122.62,45.00],[-122.59,45.53]], "spatialReference": ({ "wkid": 4326 }) }; var mp = new esri.geometry.Multipoint(points); var wm_mp = esri.geometry.geographicToWebMercator(mp); var sms = new esri.symbol.SimpleMarkerSymbol(); var infoTemplate = new esri.InfoTemplate("Vernal Pool Locations", ""); var graphic = new esri.Graphic(wm_mp, sms, '', infoTemplate); map.graphics.add(graphic); }); } dojo.ready(init); </script> </head> <body class="tundra"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
