I need to open an .mxd file on ArcMap but when I do it just comes up blank. What could be the problem and how can I fix it?
there is no data associated with the file or the links are broken and there are all these red ! symbols beside layer names, but no layers are showing..
Repairing broken data links—Help | ArcGIS for Desktop
and related links
It doesn't even show that, it just stays all blank. No question marks, nothing. It only shows up in the Catalog, where the file is located, but no other action develops.
So more info needed...
What version of arcmap are you using?
what version of arcmap was used to save it? and is it the same version as yours?
can you open up another project? just not this one?
was the project inside a zip file and you forgot to unzip it?
are you trying to load the project from a usb drive? sometimes arc* doesn't like them
more to come... you need to provide more details before we suggest using the ...
Using the MXD Doctor utility—Help | ArcGIS for Desktop
I have the 10.3.1, the file was created with 10.4.1. I tried the save as copy function to make it compatible, didn't work. So now I'm downloading the 10.4.1 version to see if that will fix it. If not, what could it be? There are two .dbf folders with the .mxd file, so I guess all the info needed is there.
