Add an offset field and calculate it to 12 or -12 (experiment) and make the summary table a new line event table with the offset field option set. The lines will follow the road between the two point measures with a 12 ft offset.
This will offset the line forward or back 12 feet along the road, not left or right, correct? I believe the OP wants a sidewalk line, at least that's what I was picturing.
I am trying to create a vegetation management layer that is offset the road centerline on both sides but is interrupted by no spray areas along that line. I am trying to figure out how to have the offset lines be symbolized with one color for spray zone and a different color for no spray zones. I sounds like I can offset the centerline how you described above but would I need to break each offset line at the milepost where the no spray zone is for it to symbolize correctly? My other thought was just offset the centerline at 10, -10 and offset the no spray zones at 8, -8. I am hoping this all makes sense?
