Was this question about linking a geoform to a geoprocessing service ever answered? I am looking to do the same thing.
Best,Sabina
Hi Chris,
I'm looking to do a similar task; enabling a form within a webmap that allows for both user input in the form of textboxes and user interaction with the map (gathering x, y location) - these would be the inputs to a geoprocessing service that would run in the map. Is this something that can be done with a GeoForm or with the Developer Edition of Web App Builder?
Thanks in advance for your feedback.
Jacqueline
Tommy- Yes and No. GeoForm is a javascript web app template that is fed by a web map. That web map could come from a portal instance hosted on premise by your organization. As you may now, starting with ArcGIS Server 10.3, all on-maintenance server licenses come with Portal for ArcGIS as well as a number of named user accounts (depending on your server level). So you will need Portal to run GeoForm, but you will begin to get Portal free (10.3 is prerelease in Sept. and officially released in Nov.) So you won't need ArcGIS Online to use it, but you will need to set up a Portal for your organization. Does that make sense?
Chris
We are are using ArcServer. We do not use ArcGIS Online. Is it still possible to use GeoForm?
Tommy
