//Here "f" can be "lake",and I do not know how to select the roads. ISelection selection = mapControl.Map.FeatureSelection; IEnumFeature enumF = (IEnumFeature)selection; IFeature f = null; while((f = enumF.Next()) != null) { //To do with the selected feature with 'f'. }
Description�?I would like to query Feature in a specified layer that intersects the specified Feature.For example, I would like to query all of the roads that intersect my specified lake.As the figure below,The load "1,2,3" all intersect with lake "0",so they should be query out.[ATTACH=CONFIG]28504[/ATTACH]I can just get selection feature in the MapControl,but I do not know what to do then.//Here "f" can be "lake",and I do not know how to select the roads. ISelection selection = mapControl.Map.FeatureSelection; IEnumFeature enumF = (IEnumFeature)selection; IFeature f = null; while((f = enumF.Next()) != null) { //To do with the selected feature with 'f'. }I would appreciate it if you can help me.Thanks very much.
/// <summary> /// Query feature class with specified geometry. /// </summary> /// <param name="baseGeometry">The base gemotry.</param> /// <param name="featureClass">the featurey class to query.</param> /// <param name="spatialRel">RelationShip between base geometry and query feature class.</param> /// <returns>The query result cursor.</returns> public static ESRI.ArcGIS.Geodatabase.IFeatureCursor QueryFeatureClass(ESRI.ArcGIS.Geometry.IGeometry baseGeometry, ESRI.ArcGIS.Geodatabase.IFeatureClass featureClass, ESRI.ArcGIS.Geodatabase.esriSpatialRelEnum spatialRel){ ESRI.ArcGIS.Geodatabase.ISpatialFilter spatialFilter = new ESRI.ArcGIS.Geodatabase.SpatialFilterClass(); spatialFilter.Geometry = baseGeometry; spatialFilter.SpatialRel = spatialRel; return featureClass.Search(spatialFilter,false); }
//mapControl contains all of the layers. ISelection selection = mapControl.Map.FeatureSelection; IEnumFeature enumF = (IEnumFeature)selection; IFeature f = null; while((f = enumF.Next()) != null) { //The fcQuery contains the query result. IFeatureClass fcQuery = ((IFeatureLayer)this._MapCon.get_Layer(combox_layer.SelectedIndex)).FeatureClass; IFeatureCursor fc = RelationShip.QueryFeatureClass(f.Shape, fcQuery, esriSpatialRelEnum.esriSpatialRelIntersects); IFeature fResult = null; while((fResult = fc.NextFeature()) != null) { MessageBox.Show(fResult.OID.ToString()); //To do with 'fResult'. } }
