Mark updated the download a while back - it contains a 3.0 compiled widget.
Ivan, Be sure that you are using the new WeatherUndergroundWidget.xml and notice that the name of the widget WeatherUndergroundWidget.swf may be different than what you were using in 2.3. The ReadMe.txt give you and example (towards the end) of what has to be added to the main config.xml.
2) Implementing the Weather Underground Widget we get an error message Error #2036 - we have been following the instruction in the readme file and have used the previous widget in our 2.3 web map apps.
Are you using the esri-compiled Bookmark widget?
Bookmark ... the vertical scrollbar
and Elevation Profile Widget created by markdeaton(markdeaton has provided the source code for the widget, but we don't possess the tools and the skills for re-compiling)
