Hi,I am rather a beginner with Arc GIS and I am not very experienced with AutoCAD as well. I am trying to create a TIN (and subsequently a raster) of a road section from a 3D CAD drawing. When I click on the lines in the drawing they give me the correct z coordinate and in general all the information is there.However when I open the drawing in GISMap (using ver.10) only the points from the point feature (representing the end of each curve segment) have the correct z values. These point though are not enough to create a proper TIN. The lines from the polyline feature have uniform Z value for each line; I mean one line has the same value all along. I tried to add the drawing into GIS in different ways, including CAD to Geodatabase giving it a spatial reference but the result is the same. Apparently I am doing something wrong but don�??t know what.Can somebody help please?Anna
Hi Karen,Thank you for your response.I have attached here a sample of the drawing. Please note that the lines are going low to negative values and then up again. May be this is creating the problem?To answer to your question about how I am examining the z values, in ArcGIS I am clicking on the i (identify) button and then on the line, which shows amongs other things the elevation. Or also I open the atribute table for the polyline features. However even if I am examining the z values in a wrong way, when I create a TIN it results in a flat surface.Thanks a lot for trying to help!Anna
Karen, thank you for all the information you have sent me so far �?? I really appreciate it.There are still some points though which I would like to clarify - I am sorry to be a pain, but since we have started I better get to the bottom of it.For the moment I cannot examine the z value the way you suggested since I have to wait for the licence for this particular GP tool to be activated on my PC. However, let�??s assume I did it and I see what you see. In the drawing the z values are from about -3.2 to 4.4 or somewhere around. Why the results of z values in GIS go down to -998?Are you saying that it is not a good idea to create a TIN from the point feature class created as you have described? Or you have created it only to examine the z values? Anyway these -998 values will be quite disturbing.Breaking the polylines and calculating the height �?? does it have to be done in CAD? Would you be able to give me just few guiding steps so I could ask the CAD team to do it?One way or another you have been most helpful and I thank you againA
