foreach (DataGridColumn col in PEDQueryNewDataGrid.Columns) { if (col.Header.ToString().ToLower() == "code") { gridUnmapped.Columns.Remove(col); break; } }
string bindName = "Attributes[S_" + InputPED.Text + "]"; DataGridTextColumn colPED = new DataGridTextColumn(); colPED.Header = "Code"; colPED.CanUserSort = true; colPED.Width = new DataGridLength(50); colPED.Binding = new System.Windows.Data.Binding(bindName); PEDQueryNewDataGrid.Columns.Add(colPED);
I could be wrong but I think the binding is interpreted literally in the XAML, so it's looking for an attribute name 'S_ + InputPED.Text' in your underlying data.Maybe in the Loaded event for the datagrid you can do something like this - In the XAML remove the column from the gridin the code behind string bindName = "Attributes[S_" + InputPED.Text + "]"; DataGridTextColumn colPED = new DataGridTextColumn(); colPED.Header = "Code"; colPED.CanUserSort = true; colPED.Width = new DataGridLength(50); colPED.Binding = new Binding(bindName); // assuming the datagrid is called gridData - replace with the name of your datagrid gridData.Columns.Add(colPED);
