Hallo,<\/P>
<\/P>
Ik ben op zoek naar een geoprocessingsmodel voor waternetwerk isolatie-trace die op het web kan worden ingezet.<\/P>
Ik weet dat er de Utility network trace beschikbaar is Utility Isolation Trace | ArcGIS for Utilities<\/A><\/P>maar ik denk niet dat dit hulpmiddel rekening houdt met niet-functionerende kleppen en niet-geluste hoofdleidingen, het vindt alleen de eerste verbonden klep.<\/P><\/P>alle hulp wordt gewaardeerd<\/P><\/P>bedankt<\/P><\/P>Snowvil<\/P><\/BODY><\/HTML>
bedankt<\/P>
What about a solution for working disconnected and being able to run the trace? This needs to be a priority as most small utilities do not have connectivity to web services. Please come up with a solution where the trace geoprocessing tool is download when the map is downloaded via Collector for ArcGIS. This is a perfect platform for allowing field users to run geoprocesses locally on their mobile devices and not be limited to internet connectivity.
Yes, as part of the work we are doing with utility network, the isolation trace capabilities will be available across the entire platform.
Thanks Michael,
This won't work for us because we need the functionality in the field 24/7.
Our field crew needs to do the isolation trace via the web in the field in order to close optimally the valves in a timely manner.
This is a need of ALL water utilities companies.
I would expect ESRI, as part as their water utilities apps promotion, to publish such a necessary tool, at least for their ArcGIS server/portal licensed users.
Any chance this will happen in the near future?
Rafi
We are limited by capabilities of the gp trace tools, so we will not be over to overcome these challenges. We are working on an update to our desktop trace that will return a result set and utilizing ArcRest, push that to a feature service. I put a sample video here.
https://community.esri.com/thread/168420
Sent from my Verizon Wireless 4G LTE DROID
Any replies about the isolation valve trace?
The current isolation web tool is useless for water utilities because it does not give the actual valves to close and does not select (dry up) all the valves and water meters that are dried (that are in the brances that are not connected to water sources.
Any plans to improve this tool in the near future?
