You'll probably want to use a model that uses a combination of the Con and Pick tools from the Conditional toolset. Use the Con tool (probably several iterations) to create a raster which maps out the raster cells that meet the requirement first, then use the Pick tool (with the previously mentioned output) to extract the desired values based from your set of elevation rasters.An overview of the Conditional toolset
