<DataTemplate x:Key="CommentInfoWindowTemplate"> <Grid> <Grid.RowDefinitions> <RowDefinition Height="30" /> <RowDefinition Height="100" /> <RowDefinition Height="30" /> </Grid.RowDefinitions> <Grid.ColumnDefinitions> <ColumnDefinition Width="150" /> <ColumnDefinition Width="300" /> </Grid.ColumnDefinitions> <TextBlock Grid.Row="0" Grid.Column="0" Text="Comment for user: " Foreground="Black" FontSize="12" /> <TextBox x:Name="UserID" Grid.Row="0" Grid.Column="1" /> <TextBlock Grid.Row="1" Grid.Column="0" Text="More Text" Foreground="Black" FontSize="12" /> <TextBox x:Name="CommentText" Grid.Row="1" Grid.Column="1" /> <Button Grid.RowSpan="2" Grid.Row="2" Content="Save" /> </Grid> </DataTemplate>
<DataTemplate x:Key="NewCommentInfoWindowTemplate"> <Grid x:Name="LayoutRoot" Background="White"> <Grid.RowDefinitions> <RowDefinition Height="20" /> <RowDefinition Height="30" /> <RowDefinition Height="200" /> <RowDefinition Height="30" /> </Grid.RowDefinitions> <Grid.ColumnDefinitions> <ColumnDefinition Width="134" /> <ColumnDefinition Width="316" /> </Grid.ColumnDefinitions> <StackPanel Orientation="Horizontal" HorizontalAlignment="Right" Grid.Row="0" Grid.ColumnSpan="2"> <Image x:Name="Dismiss" Style="{StaticResource dismissButton}" Height="20" ToolTipService.ToolTip="Exit" Cursor="Hand" MouseLeftButtonDown="Dismiss_MouseLeftButtonDown" /> </StackPanel> <TextBlock Text="Comment for user: " Grid.Row="1" Foreground="Black" FontSize="12" FontWeight="Bold" VerticalAlignment="Top" Margin="2" /> <TextBlock x:Name="UserID" Text="{Binding ID}" Grid.Column="1" Grid.Row="1" VerticalAlignment="Top" Margin="2" HorizontalAlignment="Left" Foreground="Black" FontSize="12" FontWeight="Bold" /> <TextBlock Grid.Row="2" Text="Comment:" Foreground="Black" FontSize="12" FontWeight="Bold" Margin="2" VerticalAlignment="Top" /> <TextBox x:Name="CommentText" Grid.Row="2" Grid.Column="1" Margin="2" VerticalAlignment="Stretch" /> <StackPanel Orientation="Horizontal" HorizontalAlignment="Right" Grid.Row="3" Grid.ColumnSpan="2"> <Button x:Name="SaveComment" Content="Save" Margin="2" MouseLeftButtonDown="SaveComment_MouseLeftButtonDown" Cursor="Hand"/> </StackPanel> </Grid> </DataTemplate>
<esri:InfoWindow x:Name="NewCommentInfoWindow" Grid.RowSpan="2" Padding="2" CornerRadius="20" Background="White" Map="{Binding ElementName=Map}" ContentTemplate="{StaticResource NewCommentInfoWindowTemplate}" />" />
private void CaptureComment_MouseClick(object sender, ESRI.ArcGIS.Client.Map.MouseEventArgs e) { //The actual coordinates ESRI.ArcGIS.Client.Geometry.MapPoint clickPoint = e.MapPoint; //Open the comment entry form and pass the coordinates ESRI.ArcGIS.Client.Geometry.Geometry g = clickPoint; Map.PanTo(g); NewCommentInfoWindow.Anchor = clickPoint; NewCommentInfoWindow.IsOpen = true; //Since a ContentTemplate is defined, Content will define the DataContext for the ContentTemplate FSRMapApplication.UserID ui = new FSRMapApplication.UserID(UserID); CommentInfoWindow.Content = ui; }
foreach (Graphic g in selected) { MyInfoWindow.Anchor = e.MapPoint; MyInfoWindow.IsOpen = true; //Since a ContentTemplate is defined, Content will define the DataContext for the ContentTemplate MyInfoWindow.Content = g.Attributes; return; }
InfoWindow window = new InfoWindow() { Anchor = e.MapPoint, Map = MyMap, IsOpen = true, ContentTemplate = LayoutRoot.Resources["LocationInfoWindowTemplate"] as System.Windows.DataTemplate, //Since a ContentTemplate is defined, Content will define the DataContext for the ContentTemplate Content = e.MapPoint };
