Dear All,
I am having some issues in trying to configure traffic on my network dataset. I have created the streets profiles table and the Profile table with the speeds but still unable to get it to show. They are in the File Geodatabase. The Clipped section of streets i am using to configure the traffic is in a feature class within the feature dataset. The traffic is every 15 mins Intervals
Please find attached my tables as i may be missing something.
I have gone through the tutorial and have created the same format as the San Diego tables and fields but still unable to configure the traffic. My data downloaded from osm, i created a shape file added the fields i required and calculated the fields , KM, Meters, FT_Minutes and TF_Minutes and other applicable fields.
Then i created a feature dataset and imported the data into a new feature class called streets. Please take a look at the two tables i created for my data the streets profile and the Profiles.
I am able to calculate a route based on the speed for the line segment in the KPH Field which is the same for both sides, my streets have different speeds for the from and to sides of the streets and im having difficulty trying to get arcgis to read the edges and calculate the speed together with my historical traffic speed profiles in the profiles table.
Hello!
Historical traffic can be pretty tough to set up correctly. It was originally designed to work with vendor data, so getting it working on you own data can be tricky. Is your ultimate goal custom live traffic? Or is historical your final step? Where does your historical data come from?
As for setting historical up, here is a list of things that you need to consider:
http://www.arcgis.com/home/item.html?id=d6bd91b2fddc483b8ccbc66942db84cb
Those are just a start. If we don't find it there, we'll keep trying.
