Hi, I want to change map service url in Web map as JSON before printing the web map? in other words , I don't want to print map object and want specify other map service url in JSON print parameter?
Not sure if I'm understanding your question 100%, but you can change the parameters of any GP task request before it is sent to the server with the setRequestPreCallback funciton: esri/request | API Reference | ArcGIS API for JavaScript 3.17
To change the URL of an operational layer you can add this to your code where you are specifying the print task:
esriRequest.setRequestPreCallback(function(ioArgs){ // check if request is a web map print request if (ioArgs.content && ioArgs.content.Web_Map_as_JSON){ var webMapAsJson = ioArgs.content.Web_Map_as_JSON; var webMapObj = JSON.parse(webMapAsJson); // iterate through operational layers on the map for (o in webMapObj.operationalLayers) { var wmo = webMapObj.operationalLayers; if (wmo.title = "MyLayer"){ wmo.url = "http://newurl"; } } } return ioArgs; })
