import arcpy arcpy.env.overwriteOutput=True arcpy.env.workspace = "D:\FacID_Python\SO_CSS_Master_9x_GDB.gdb" sinkFeatures = "D:\\FacID_Python\\SO_CSS_Master_9x_GDB.gdb\\SO_CSS_Master\\SManhole_Master" dCatchBasin = "D:\\FacID_Python\\SO_CSS_Master_9x_GDB.gdb\\SO_CSS_Master\\DCatchBasin_Master" geometricNetwork = "D:\\FacID_Python\\SO_CSS_Master_9x_GDB.gdb\\SO_CSS_Master\\SO_CSS_Master_Net" mxd = arcpy.mapping.MapDocument("D:\FacID_Python\Working.mxd") sinkList = [] rows = arcpy.SearchCursor(sinkFeatures) row = rows.next() while row: featureID = row.OBJECTID if featureID not in sinkList: sinkList.append(featureID) row = rows.next() del rows print sinkList sinkCount = len(sinkList) for each in range(sinkCount): print "%s of %s" % (each +1, sinkCount) sinkWhere = '"OBJECTID" = %s' % sinkList[each] if arcpy.Exists("TempSinkLayer"): arcpy.Delete_management("TempSinkLayer") arcpy.MakeFeatureLayer_management(sinkFeatures, "TempSinkLayer", sinkWhere) cursor = arcpy.SearchCursor("TempSinkLayer") sink = cursor.next() while sink: facID = sink.getValue("FACILITYID") print facID sink = cursor.next() del sink del cursor try: outGroupLayer = str("Trace" + facID) arcpy.SetFlowDirection_management(geometricNetwork, "WITH_DIGITIZED_DIRECTION") arcpy.TraceGeometricNetwork_management(geometricNetwork, outGroupLayer, "TempSinkLayer", "TRACE_UPSTREAM", "", "", "", "", "", "", "" ,"", "", "", "", "", "", "") except: print "Can't trace" try: dCatchLayer = str(facID + "dCatch") arcpy.SelectData_management(outGroupLayer, "DCatchBasin_Master") arcpy.MakeFeatureLayer_management("DCatchBasin_Master", dCatchLayer) result = int(arcpy.GetCount_management(dCatchLayer).getOutput(0)) print result dCatchs = arcpy.UpdateCursor(dCatchLayer) dCatch = dCatchs.next() fieldID = "DnComboFacID" while dCatch: dCatch.setValue(fieldID, facID) dCatchs.updateRow(dCatch) dCatch = dCatchs.next() del dCatch del dCatchs arcpy.Delete_management(dCatchLayer) arcpy.Delete_management("DCatchBasin_Master") arcpy.SelectLayerByAttribute_management("DCatchBasin_Master", "CLEAR_SELECTION") ##for df in arcpy.mapping.ListDataFrames(mxd): ##for lyr in arcpy.mapping.ListLayers(mxd, "", df): ##if lyr.name == "Trace" + facID: ##arcpy.mapping.RemoveLayer(df, lyr) ##else: ##pass except: print "not working"
import arcpy arcpy.env.overwriteOutput=True arcpy.env.workspace = "D:\FacID_Python\SO_CSS_Master_9x_GDB.gdb" sinkFeatures = "D:\\FacID_Python\\SO_CSS_Master_9x_GDB.gdb\\SO_CSS_Master\\Export_Output" dCatchBasin = "D:\\FacID_Python\\SO_CSS_Master_9x_GDB.gdb\\SO_CSS_Master\\DCatchBasin_Master" geometricNetwork = "D:\\FacID_Python\\SO_CSS_Master_9x_GDB.gdb\\SO_CSS_Master\\SO_CSS_Master_Net" mxd = arcpy.mapping.MapDocument("D:\FacID_Python\Working.mxd") sinkList = [] rows = arcpy.SearchCursor(sinkFeatures) row = rows.next() while row: featureID = row.OBJECTID if featureID not in sinkList: sinkList.append(featureID) row = rows.next() del rows print sinkList sinkCount = len(sinkList) for each in range(sinkCount): print "%s of %s" % (each +1, sinkCount) sinkWhere = '"OBJECTID" = %s' % sinkList[each] if arcpy.Exists("TempSinkLayer"): arcpy.Delete_management("TempSinkLayer") arcpy.MakeFeatureLayer_management(sinkFeatures, "TempSinkLayer", sinkWhere) cursor = arcpy.SearchCursor("TempSinkLayer") sink = cursor.next() while sink: facID = sink.getValue("FACILITYID") print facID sink = cursor.next() del sink del cursor try: outGroupLayer = "Trace" + facID arcpy.SetFlowDirection_management(geometricNetwork, "WITH_DIGITIZED_DIRECTION") arcpy.TraceGeometricNetwork_management(geometricNetwork, outGroupLayer, "TempSinkLayer", "TRACE_UPSTREAM", "", "", "", "", "", "", "" ,"", "", "", "", "", "", "") except: print "Can't trace" try: dCatchLayer = facID + "dCatch" arcpy.SelectData_management(outGroupLayer, "DCatchBasin_Master") arcpy.MakeFeatureLayer_management("DCatchBasin_Master", dCatchLayer) result = int(arcpy.GetCount_management(dCatchLayer).getOutput(0)) print result except: print "can't make feature layer or access selection" try: dCatchs = arcpy.UpdateCursor(dCatchLayer) dCatch = dCatchs.next() fieldID = "DnComboFacID" while dCatch: dCatch.setValue(fieldID, facID) dCatchs.updateRow(dCatch) dCatch = dCatchs.next() del dCatch del dCatchs except: print "can't update rows" try: arcpy.Delete_management(dCatchLayer) except: print "can't delete the feature layer" try: arcpy.SelectLayerByAttribute_management("DCatchBasin_Master", "CLEAR_SELECTION") for df in arcpy.mapping.ListDataFrames(mxd): for lyr in arcpy.mapping.ListLayers(mxd, "", df): if lyr.name == "Trace" + facID: arcpy.mapping.RemoveLayer(df, lyr) else: pass except: print "can't delete the group layer"
# make a list of the feature IDs theSource = r"C:\some.gdb\FeatureClass" cur = arcpy.SearchCursor(theSource) theIdList = [] for row in cur: theID = row.OBJECTID if theID not in theIdList: theIdList.append(theID) del cur # count the entries in the list idCount = len(idList) for each in range(idCount): print "%s of %s" % (each + 1, idCount) # build a feature where clause segWhere = '"OBJECTID" = %s' % idList[each] # make a layer of each feature in fc if arcpy.Exists("MyTempLayer"): arcpy.Delete_management(("MyTempLayer") arcpy.MakeFeatureLayer_management(theSource, "MyTempLayer", segWhere) ### Do stuff to that feature here....
