Ted,Can you clarify this post? This is what I think you are doing...From the Map1. You find a layer on your local server and "Use as basemap". Everything is working fine at this point.2. Then you add a "real basemap". How are you doing this? Are you choosing from the Basemap button on the toolbar? If so, you've just replaced your custom basemap with this new basemap. So you won't see your data anymore.3. Then you add your layer over the basemap. Is your layer a dynamic map service or cached? What basemap are you trying to display it over?Are your services available for me to try? I am not able to reproduce the problem you are seeing. If you could help me narrow down the problem, that would be great.Thanks,Mike
