private Bitmap GetImageFromJpegExporter(tagRECT rect, CancelTracker trackCancel) { string filename = Guid.NewGuid().ToString(); try { tagRECT exportRECT = _mapDocument.ActiveView.ExportFrame; //Create a new envelope object and populate it with the values from exportRECT. // We need to do this because the exporter object requires an envelope object // instead of a tagRECT structure. IEnvelope pPixelBoundsEnv = new EnvelopeClass(); pPixelBoundsEnv.PutCoords(exportRECT.left, exportRECT.top, exportRECT.right, exportRECT.bottom); IExport export = new ExportJPEGClass { Resolution = 96, ExportFileName = filename, PixelBounds = pPixelBoundsEnv }; Stopwatch watch = new Stopwatch(); watch.Start(); int hwnd = export.StartExporting(); _mapDocument.ActiveView.Output(hwnd, 96, ref rect, _mapDocument.ActiveView.Extent, trackCancel); export.FinishExporting(); export.Cleanup(); watch.Stop(); Trace.WriteLine("Export took " + watch.ElapsedMilliseconds + " ms"); Bitmap fromFileBitmap = new Bitmap(filename); // Copy fromFileBitmap because it keeps a lock on the file Bitmap returnBitmap = new Bitmap(fromFileBitmap); fromFileBitmap.Dispose(); return returnBitmap; } finally { if(File.Exists(filename)) { try { File.Delete(filename); } catch (Exception) { } } } }
