I have some data in Michigan State Plane NAD83 in International feet. Does anyone know if this is accounted for when adding this data set to a map in Michigan State Plane 83 in USfeet?
Regards,
Jim
Yes, when we unproject/project data, we look at the actual unit that are listed in the coordinate system definition. The false easting/false northing values must be in the same unit so if you compare the int'l ft and US survey ft definitions, you should see slightly different numbers.
Melita
If they do have a different code EPSG code, I presume they would project on the fly
Spatial Reference List -- Spatial Reference
That is my quandary. The FIPS code is the same, but the units are different. Does arcgis recognize feet_int versus USfeet and account for it?
The data that I have produced and the data that someone else has produced do not align, so I am fishing for the reason.
Regards, Jim
Jim Cousins
GIS Project Scientist
S.S. Papadopulos & Associates, Inc.<http://www.sspa.com/>
7944 Wisconsin Avenue | Bethesda, Maryland 20814
Direct: (301) 500-2271 | Office: (301) 718-8900
jcousins@sspa.com<mailto:jcousins@sspa.com>
PRIVILEGED AND CONFIDENTIAL: This email and any attachments are intended only for the addressee(s) and may be confidential, proprietary, privileged, or otherwise protected by law from disclosure or use by a third party. If you are not the intended recipient, please delete this message and its attachments, and destroy any electronic or hard copies that you may have created.
Isn't the FIPS code a county code (Canadian here, so bear with me).
I was more interested in what the actual coordinate system was for each file. If they were defined the same but differ in placement, then the units and/or datum (nad whatever) would account for the shift).
Check via properties
Thank you Melita, this answers my question.
Best Regards,
