I think you nailed it. I'm just unsure how to
why couldn't you just set the attribute in a loop on the selected features?
Is there a way to take advantage of the FeatureData Grid to do this. It seems like I can change the values in the FeatureData Grid Cells but can't save the changes.
private void FeatureLayer_PropertyChanged(object sender, PropertyChangedEventArgs e){ var l = sender as FeatureLayer; if (e.PropertyName == "SelectedGraphics") { var total = (from g in l.SelectedGraphics select (int)g.Attributes["ftype"]).Sum(); }}
private void ExcuteBatchUpdate_Click(object sender, RoutedEventArgs e) { }
private void EditorWidget_EditCompleted(object sender, Editor.EditEventArgs e) { int total = 0; foreach (var edit in e.Edits) { if (edit.Graphic.Selected) total += (int)edit.Graphic.Attributes["ftype"]; } }
private void FeatureLayer_PropertyChanged(object sender, PropertyChangedEventArgs e) { var l = sender as FeatureLayer; if (e.PropertyName == "SelectedGraphics") { var total = (from g in l.SelectedGraphics select (int)g.Attributes["ftype"]).Sum(); } }
