Hi FaisalIf you are working in version environment the records are not added to the base table until you compress you geodatabase.Even then if anybody is looking on the layers the records from the delta tables (A & D) might not be written into base.You can check the �??move to base�?� checkbox when you register the layer as version or work without versioning at all.Have FunMody
When you open feature class properties in general tab it is written in the version group on the bottom of the page.Mody
