Does anyone know of a python script that could be run against a table that would generate a python script that could be used to recreate the table in code?
I like MySQL's SHOW CREATE TABLE, so I created something similar with arcpy. One script reads the table and prints a list of field information that I can modify as desired and use to create a new feature or table.
<SPAN class="keyword token">import</SPAN> arcpy <SPAN class="keyword token">from</SPAN> arcpy <SPAN class="keyword token">import</SPAN> env <SPAN class="comment token"># Set the current workspace</SPAN> env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"C:\Path\To\file.gdb"</SPAN> <SPAN class="keyword token">print</SPAN> env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="keyword token">print</SPAN> <SPAN class="comment token"># Get the list of standalone tables in the geodatabase</SPAN> <SPAN class="comment token">#</SPAN> tableList <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># for features</SPAN> <SPAN class="comment token"># tableList = arcpy.ListTables() # for tables</SPAN> <SPAN class="keyword token">print</SPAN> tableList <SPAN class="keyword token">for</SPAN> table <SPAN class="keyword token">in</SPAN> tableList<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="keyword token">print</SPAN> table dbTable <SPAN class="operator token">=</SPAN> env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\\"</SPAN> <SPAN class="operator token">+</SPAN> table fieldList <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFields<SPAN class="punctuation token">(</SPAN>dbTable<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'\t['</SPAN> <SPAN class="keyword token">for</SPAN> field <SPAN class="keyword token">in</SPAN> fieldList<SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># print("\t{0} is a type of {1} with a length of {2}"</SPAN> <SPAN class="comment token"># .format(field.name, field.type, field.length)) </SPAN> <SPAN class="comment token"># Print field properties</SPAN> <SPAN class="comment token">#</SPAN> <SPAN class="comment token"># print("Name: {0}".format(field.name))</SPAN> <SPAN class="comment token"># print("\tBaseName: {0}".format(field.baseName))</SPAN> <SPAN class="comment token"># print("\tAlias: {0}".format(field.aliasName))</SPAN> <SPAN class="comment token"># print("\tLength: {0}".format(field.length))</SPAN> <SPAN class="comment token"># print("\tDomain: {0}".format(field.domain))</SPAN> <SPAN class="comment token"># print("\tType: {0}".format(field.type))</SPAN> <SPAN class="comment token"># print("\tIs Editable: {0}".format(field.editable)) </SPAN> <SPAN class="comment token"># print("\tIs Nullable: {0}".format(field.isNullable)) </SPAN> <SPAN class="comment token"># print("\tRequired: {0}".format(field.required))</SPAN> <SPAN class="comment token"># print("\tScale: {0}".format(field.scale))</SPAN> <SPAN class="comment token"># print("\tPrecision: {0}".format(field.precision))</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'\t["'</SPAN> <SPAN class="operator token">+</SPAN> field<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">+</SPAN> <SPAN class="string token">'",'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>field<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">==</SPAN> <SPAN class="string token">"String"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'"TEXT", '</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'"'</SPAN> <SPAN class="operator token">+</SPAN> str<SPAN class="punctuation token">(</SPAN>field<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">'",'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"\"{0}\", "</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>field<SPAN class="punctuation token">.</SPAN>type<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>upper<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">print</SPAN> '"<SPAN class="comment token">#",',</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'"'</SPAN> <SPAN class="operator token">+</SPAN> field<SPAN class="punctuation token">.</SPAN>aliasName <SPAN class="operator token">+</SPAN> <SPAN class="string token">'",'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">if</SPAN> len<SPAN class="punctuation token">(</SPAN>field<SPAN class="punctuation token">.</SPAN>domain<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'"'</SPAN> <SPAN class="operator token">+</SPAN> field<SPAN class="punctuation token">.</SPAN>domain <SPAN class="operator token">+</SPAN> <SPAN class="string token">'"],'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> '"<SPAN class="comment token">#",',</SPAN> <SPAN class="keyword token">print</SPAN> '"<SPAN class="comment token">#"],' # Default</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'\t]'</SPAN> <SPAN class="comment token"># Fields: [ 0:Name, 1:Type, 2:Size, 3:Alias, 4:Domain 5:Default ] use "#" for blanks</SPAN> <SPAN class="comment token"># Field type is returned as:</SPAN> <SPAN class="comment token"># SmallInteger, Integer, Single, Double, String, Date, OID, Geometry, Blob</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
This script produces something like:
businesses <SPAN class="punctuation token">[</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"OID"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "OBJECTID", "#", "#"],</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Business"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"TEXT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"50"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Business Name"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "#"],</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Address"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"TEXT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"50"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Business Address"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "#"],</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"City"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"TEXT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"20"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Business City"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "#"],</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Zip"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"TEXT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"10"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Business Zip"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "#"],</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Phone"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"TEXT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"16"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Business Phone"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "#"],</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"GlobalID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"GLOBALID"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "GlobalID", "#", "#"],</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"CreationDate"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DATE"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "CreationDate", "#", "#"],</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Creator"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"TEXT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"50"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Creator"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "#"],</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"EditDate"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DATE"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "EditDate", "#", "#"],</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Editor"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"TEXT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"50"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Editor"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "#"],</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Shape"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"GEOMETRY"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "Shape", "#", "#"],</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"POINT_X"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "POINT_X", "#", "#"],</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"POINT_Y"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">,</SPAN> "<SPAN class="comment token">#", "POINT_Y", "#", "#"],</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I then modify the list by modifying/removing/adding fields. From there, I recreate an empty table/feature using something like this (this is for a feature so there are some geometry functions added).
# Import system modules import arcpy from arcpy import env # name of geodatabase geoDB = r"C:\Path\To\file.gdb" # set environment settings env.workspace = geoDB def new_feature(dbFeature, dbAttributes, geoDB): # create the table print "\nCreating feature: " + dbFeature # set local variables geometry_type = "POINT" template = "#" has_m = "DISABLED" has_z = "DISABLED" # Use SpatialReference to set object reference - system name, projection file or authority code spatial_reference = arcpy.SpatialReference("WGS 1984 Web Mercator (auxiliary sphere)") # spatial_reference = arcpy.SpatialReference("WGS 1984") # Execute CreateFeatureclass # CreateFeatureclass_management (out_path, out_name, {geometry_type}, {template}, {has_m}, {has_z}, {spatial_reference}, # {config_keyword}, {spatial_grid_1}, {spatial_grid_2}, {spatial_grid_3}) arcpy.CreateFeatureclass_management(geoDB, dbFeature, geometry_type, template, has_m, has_z, spatial_reference) # add the fields print "Adding attributes: " for new_field in dbAttributes: # add new field print "\t" + new_field[0] # all fields using domains are non-nullable if (new_field[4] == "#"): nullable = "NULLABLE" else: nullable = "NON_NULLABLE" # AddField_management (in_table, field_name, field_type, {field_precision}, {field_scale}, # {field_length}, {field_alias}, {field_is_nullable}, {field_is_required}, {field_domain}) arcpy.AddField_management(dbFeature,new_field[0],new_field[1],"#","#", new_field[2],new_field[3],nullable,"NON_REQUIRED",new_field[4]) # assign default value as specified if ( new_field[5] <> "#" ) : # AssignDefaultToField_management (in_table, field_name, default_value, {subtype_code}) arcpy.AssignDefaultToField_management(dbFeature,new_field[0],new_field[5],"#") if __name__ == "__main__": # Fields: [ 0:Name, 1:Type, 2:Size, 3:Alias, 4:Domain, 5:Default] use "#" for blanks dbFeature = new_business" dbAttributes = [ ["Business", "TEXT", "50", "Business Name", "#", "#"], ["Address", "TEXT", "50", "Business Address", "#", "#"], ["City", "TEXT", "20", "Business City", "#", "#"], ["Zip", "TEXT", "10", "Business Zip", "#", "#"], ["Phone", "TEXT", "16", "Business Phone", "#", "#"], ["Licensed","TEXT","1","Business Licensed","YN","?"], # added domain choices: ?, Y, N ] new_feature(dbFeature, dbAttributes, geoDB) print print "Processing complete." <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
This gives you the basic workings of the process. Except for the geometry, creating a data table is similar. You can capture more of the field's properties in the first script to use in the second (field.editable, field.precision, etc.). Hope this helps.
Joshua
Thanks for the suggestion however it won't work for what I need. In the end I need to develop python scripts to create table documents, relationship classes, etc. and T-SQL to update data, create triggers, etc. in a MS Azure environment as the final app requires a substantial amount of database automation that cannot be accomplished with ESRI only toolsets.
If your intent is to create a new feature class with the same schema as another, then I suggest looking at Export XML Workspace Document—Data Management toolbox | ArcGIS Desktop. Since the Describe Field object properties and Add Field parameters don't line up cleanly, you have to spend time massaging the output before using it to create a new feature class. Using Export XML Workspace Document, which can be used for individual feature classes, a fully-specified schema is created that can be used directly to create another feature class.
Oops, yet strange cause I marked his answer as correct. Thanks
Then i will unmark you answer as correct and provide the proper attribution to Randy
Randy
A MILLION thanks. You just saved me a day of coding.
much functionality is with the arcpy.da.Describe section of arcpy
Describe—ArcPy Functions | ArcGIS Desktop
specific properties can be once you have retrieved the table
Table properties—ArcPy Functions | ArcGIS Desktop
Then it is a matter of cycling through the Field objects and retrieving their properties.
Field—ArcPy classes | ArcGIS Desktop
FieldInfo—ArcPy classes | ArcGIS Desktop
The assembled information can be put back together to create a new table object with a new name.
Dan
The tool would take an input table and create a script that could be run to recreate the table, i.e. add fields, field types, etc. No data would be copied just the the table layout.
What do you mean by 'recreate the table'...
Make all the fields? add the content?
What would be the source of the inputs if it wasn't the table itself?
A concrete example?
