I am combing multiple rasters and having problems joining stand-alone tables to get the descriptive attributes. I have separated this into several models because two of the input GRIds and stand-alone tables change with each run, and there 7 runs. Setting these up as parameters that I could change just did not work. In model builder, it does not "see" the field in the combined rasters until it has run and made the combined raster. The attributes show as Band1-bandx. Even though some of the attributes will be the same, when the model is run on another set, it flags it as an error when I enter the expected attribute. What an I doing wrong? I Guess I could create a model that combines the rasters, then a second model that joins the attributes.
