I was able to get the join to work fine they way Jon explained above for version 2.1, but not 2.2 for my Query Widget. The only way my widget works is if I set <fields all="true">. I soon as I turn it to false the Widget will not work. I set it to false I get this error in my widget when it opens.[RPC Fault faultString="Error#2032:Stream Error. URL: <mine URL>/query?
Hello,In an attempt to get data from a SQL data source, I have created a join between one of my map service layers and the SQL table. It seemed to work and the SQL layers are visible in my rest service. However, when I try to use the joined service in Flex Viewer 2.1, especially in my Search widget, I am getting errors. Does anyone know if this will work?Thanks!
