Hi,I can't get local modules to reload anymore with the namespace change. In the code below I can not get into init_2 (I get cross-domain loading errors), though the in-line dijit is created just fine. Hoping you can see where I have gone wrong without having to create your own test utility resource to try this one out.<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head> <title>(esriDojo Testing)</title> <!-- styling --> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.0/js/dojo/dijit/themes/tundra/tundra.css"/> <!-- Set dojo configuration --> <script type="text/javascript"> djConfig = { isDebug: true, parseOnLoad: true, xdWaitSeconds: 10, scopeMap: [ ["dojo", "esriDojo"], ["dijit", "esriDijit"], ["dojox", "esriDojox"] ], baseUrl: "./", modulePaths: { "MyModules": "./MyModules" } }; </script> <!-- v2.0 uses Dojo v1.4.2 --> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.0"></script> <script type="text/javascript"> esriDojo.require("dijit.form.DropDownButton"); esriDojo.require("dijit.Menu"); esriDojo.addOnLoad(init_1); function init_1() { console.log("in init_1()"); esriDojo.require("MyModules.Utilities.MyTestUtility"); esriDojo.addOnLoad(init_2); } function init_2(){ console.log("in init_2()"); } </script> </head><body class="tundra"> <button esriDojoType="dijit.form.DropDownButton"> <span>Test DDBtn</span> <div esriDojoType="dijit.Menu"> <div esriDojoType="dijit.MenuItem" label="Some menu item 1"> <script type="dojo/method" event="onClick" args="evt"> console.log("ok 1"); </script> </div> <div esriDojoType="dijit.MenuItem" label="Some menu item 2"> <script type="dojo/method" event="onClick" args="evt"> console.log("ok 2"); </script> </div> </div> </button></body></html>Loren
