<!doctype html> <html> <head> <meta charset="utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title></title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/dojo/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; padding: 0 0 5px 0; text-align: center; } .shadow { -moz-box-shadow: 0 0 5px #888; -webkit-box-shadow: 0 0 5px #888; box-shadow: 0 0 5px #888; } #map{ margin: 0; padding: 0; } #feedback { background: #fff; color: #000; position: absolute; font-family: arial; height: auto; right: 30px; margin: 5px; padding: 10px; top: 30px; width: 300px; z-index: 40; } #feedback a { border-bottom: 1px solid #888; color: #444; text-decoration: none; } #feedback a:hover, #feedback a:active, #feedback a:visited { border: none; color: #444; text-decoration: none; } #note { font-size: 80%; font-weight: 700; padding: 0 0 10px 0; } #info { padding: 10px 0 0 0; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.layers.wms"); dojo.require("esri.layers.FeatureLayer"); dojo.require("esri.dijit.Print"); var app = {}; app.printUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task"; function myFunction() { esri.config.defaults.io.proxyUrl = "/proxy/proxy.ashx"; urlwms = "http://wms.openweathermap.org/service"; var wmsLayer = new esri.layers.WMSLayer(urlwms, { "type": "wms", "transparentBackground":true, "visibleLayers":"pressure_cntr", "version": "1.1.1" }); wmsLayer.setImageFormat("png"); app.map.addLayer(wmsLayer); } function init() { esri.config.defaults.io.proxyUrl = "/proxy/proxy.ashx"; var initialExtent = new esri.geometry.Extent({"xmin":1265873.30, "ymin":4392682.98, "xmax": 2060818.40, "ymax": 4759580.72,"spatialReference":{"wkid":102100}}); app.map = new esri.Map("map", { basemap: "hybrid", extent: initialExtent, zoom: 8 }); // get print templates from the export web map task var printInfo = esri.request({ "url": app.printUrl, "content": { "f": "json" } }); printInfo.then(handlePrintInfo, handleError); } function handlePrintInfo(resp) { var layoutTemplate, templateNames, mapOnlyIndex, templates; layoutTemplate = dojo.filter(resp.parameters, function(param, idx) { return param.name === "Layout_Template"; }); if ( layoutTemplate.length == 0 ) { console.log("print service parameters name for templates must be \"Layout_Template\""); return; } templateNames = layoutTemplate[0].choiceList; // remove the MAP_ONLY template then add it to the end of the list of templates mapOnlyIndex = dojo.indexOf(templateNames, "MAP_ONLY"); if ( mapOnlyIndex > -1 ) { var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0]; templateNames.push(mapOnly); } // create a print template for each choice templates = dojo.map(templateNames, function(ch) { var plate = new esri.tasks.PrintTemplate(); plate.layout = plate.label = ch; plate.format = "PDF"; plate.layoutOptions = { "authorText": "May by: Esri's JS API Team", "copyrightText": "<copyright info here>", "legendLayers": [], "titleText": "Pool Permits", "scalebarUnit": "Miles" }; return plate; }); // create the print dijit app.printer = new esri.dijit.Print({ "map": app.map, "templates": templates, url: app.printUrl }, dojo.byId("print_button")); app.printer.startup(); } function handleError(err) { console.log("Something broke: ", err); } dojo.ready(init); </script> </head> <body class="tundra"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"> <div id="feedback" class="shadow"> <h3> Print Templates Using Layer WMS </h3> <button data-dojo-type="dijit.form.Button" onclick="myFunction()">WMS Layer</button> <div id="info"> <div id="note"> Note: This sample uses an ArcGIS Server version 10.1 export web map task. </div> <!-- that will be used for the print dijit --> <div id="print_button"></div> </div> </div> </div> </div> </body> </html>
