Hi all I want to convert lines feature that is directioned at random to polygons by python script, but my arcmap has no a license of 'feature to polygon'. How to realize it?
And here is the code to cut all the pie polygons with the fault polylines:
import arcpy def main(): fc_pie = r'C:\GeoNet\SplitBalls\shp\focal_sml_pie.shp' fc_faults = r'C:\GeoNet\SplitBalls\shp\focal_sml_faults.shp' fc_result = r'C:\GeoNet\SplitBalls\shp\pie_pieces01.shp' arcpy.env.overwriteOutput = True # create dct with faults dct_faults = {r[0]: r[1] for r in arcpy.da.SearchCursor(fc_faults, ('OID@', 'SHAPE@'))} # loop through pie polygons lst_polygons = [] with arcpy.da.SearchCursor(fc_pie, ('SHAPE@')) as curs_pie: for row_pie in curs_pie: polygon = row_pie[0] # get list of faults for current pie lst_faults_pie = getFaults(polygon, dct_faults.values()) # cut pie based on faults lst_polygons_pie = [polygon] for fault in lst_faults_pie: lst_polygons_pie = splitPolygon(lst_polygons_pie, fault) # add polygons to list lst_polygons.extend(lst_polygons_pie) # write the pie pieces to a new featureclass arcpy.CopyFeatures_management(lst_polygons, fc_result) def getFaults(polygon, lst_faults): '''Get list of fault polylines for pie polygon''' lst_faults_pie = [] for fault in lst_faults: mid_pnt = fault.positionAlongLine(0.5, True) if polygon.contains(mid_pnt): lst_faults_pie.append(fault) return lst_faults_pie def splitPolygon(lst_polygons, polyline): '''split pie polygon with fault polyline''' lst_pols = [] for polygon in lst_polygons: try: lst_pols += polygon.cut(polyline) except Exception as e: print "Error:", e pass return lst_pols if __name__ == '__main__': main()
Also find attached the resulting shapefile.
are you familiar with ... Writing geometries—Help | ArcGIS for Desktop
and insertcursors? do you have a way of orientating your polylines so that they connect? or are they disconnected and you wish to get a bounding container from the features? Perhaps an image of what you are working with might help, and a statement of your python and arcpy knowledge
Thanks for your reply. What i want is to make a code run at standard arcmap version which using a simple script 'feature to polygon' or 'split polygon by lines ' that make things perfectly at a advanced version.
I understand your request, but the remaining questions in my post need to be answered. Replicating the functionality of tools that are only available at an advanced license level is not simple... otherwise they would be available at the lower level already.
I have worked on a toolbox with functionality that is normally available with the Advanced license level only to make it available at a Basic license. However, the tool to convert unstructured lines to polygons, creating intersections, etc, is one of the tools that I will not even try to implement. As Dan mentions, this tool is very complex and not easy to implement with arcpy and only the Basic license level.
There are also third party tools like ETGeowizards and Xtools that have this sort of functionality.
Hi, thanks for the suggestion. Actually I need the function in an arcpy appliction.
Could you post an example of some lines that you wish to convert to polygons, just to see how complex the situation is? If not too complex, there are ways to do this with arcpy and a Basic license.
I have many balls must be divided by the red lines of varied oriented. In my original codes, construct balls and lines in memory at first, then copy them as polygon feature and line feature seperately, 'arcpy.FeatureToPolygon_management([balls,lines],"in_memory")' finally. It's simple. Don't care where and how the lines intersect with balls. But need advanced license.
With POLYGON method, may be the intersect or the nearest points between lines, lines and ball, must be got, then regroup these point arrays to form polygons. Don't have idea yet about what's the best way to get the 'intersect' points (all the geometries are constructed from points, they may have no common point) .
