Please see this help page:http://resources.arcgis.com/en/help/main/10.1/#/Printing_maps_that_contain_secured_services/0154000005q3000000/
<map esrilogovisible="true" openhandcursorvisible="true" scalebarvisible="true" zoomslidervisible="false" wraparound180="true" addarcgisbasemaps="true" initialextent="-13458291.5379666 4173046.713184668 -13425614.70837473 4191582.6925437986" wkid="102100" top="40"> <operationallayers> <layer type="dynamic" label="SaveTheBay" url="http://sampleserver6.arcgisonline.com/arcgis/rest/services/SaveTheBay/MapServer" visible="true"/> </operationallayers> </map>
<?xml version="1.0" ?> <configuration> <taskurl>http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task</taskurl> <title visible="false"/> <copyright visible="false"/> <author visible="false"/> <usescale visible="true"/> </configuration>
Here's a working example. The login is: user1/user1map config: <map esrilogovisible="true" openhandcursorvisible="true" scalebarvisible="true" zoomslidervisible="false" wraparound180="true" addarcgisbasemaps="true" initialextent="-13458291.5379666 4173046.713184668 -13425614.70837473 4191582.6925437986" wkid="102100" top="40"> <operationallayers> <layer type="dynamic" label="SaveTheBay" url="http://sampleserver6.arcgisonline.com/arcgis/rest/services/SaveTheBay/MapServer" visible="true"/> </operationallayers> </map>print widget config:<?xml version="1.0" ?> <configuration> <taskurl>http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task</taskurl> <title visible="false"/> <copyright visible="false"/> <author visible="false"/> <usescale visible="true"/> </configuration>
Does it print fine if you turn off security on your service? If not, then it's probably a different problem.What is the URL to your print service? That server needs to be able to connect to your service.Can you use a tool like HttpFox to see the print request and response?The client should be sending the short term token as part to the url in the Web_Map_as_JSON parameter.
This is the kind of problem I'm referring to:http://forums.arcgis.com/threads/62538-Error-when-using-print-service-on-dynamic-layer?p=221720&viewfull=1#post221720If the print task and map services are on the same GIS server, the server is still making a HTTP request to the url in the web map json, so it's acting as a client to itself.
