private function removeDummy(event:AppEvent):void { var widget:IVisualElement; var data:Object = event.data; curId = data.id as Number; for (var i:int = 0; i < widgetContainer.numElements; i++) { widget = widgetContainer.getElementAt(i); var baseWidget:InitMinWidget = widget as InitMinWidget; if(baseWidget!=null){ if (baseWidget.myId == curId) { widgetContainer.removeElement(baseWidget); } } } } public function addMinElement(element:IVisualElement):IVisualElement{ if (element as SkinnableContainer){ // Added by FT to add the element in widget Container group if(element!=null) this.widgetContainer.addElement(element); } return element; } private function addWidget(element:IVisualElement):void { var baseWidget:IBaseWidget = element as IBaseWidget; baseWidget.isDraggable = this.isDraggable; constrainWidget(baseWidget); //widgetContainer.addElement(element); widgetContainer.addElementAt(element,Number(baseWidget.widgetId)); }
private function preloadNextWidget():void { if (preloadArray.length > 0) { var id:Number = preloadArray[0].id; preloadArray.splice(0, 1); //AppEvent.dispatch(AppEvent.WIDGET_RUN, id); var preload:String = configData.widgets[id].preload; var label:String = configData.widgets[id].label; var icon:String = configData.widgets[id].icon; var config:String = configData.widgets[id].config; var url:String = configData.widgets[id].url; var preWidget:InitMinWidget = new InitMinWidget(); preWidget.myId = id preWidget.myLabel = label; preWidget.myIcon = icon; var wgtContainer:IWidgetContainer = configData.widgetContainers[0].container.obj; wgtContainer.addMinWidget(preWidget); preInitWidgetArr.push(preWidget); } }
Finally how can i move the widget container controller to start the first widget from specific location.
