I tried one of the sample python code to send email to the active database user as part of the database maintenance procedure. But I have a problem in sending it because of the domain included in the username (e.g. xyz\username)...So, I want to remove the domain name and the backslash and retain only the username as the email list. (Please check the attached python code).
Dan, when I ran the code userList = [user.Name for user in arcpy.ListUsers(workspace)], it returns a list of users with the format 123456\\xyz.com.sa. when I ran your suggested code emails=[name.split("\\")[-1] for name in userList], it returns a list of username only but have a little problem there's a double quote at the end of the username....[u'123456"', u'6789"'].
is user.Name returning the string in the format you showed
why don't you show what the actual emailList looks like minus the "@xyz.com.sa" stuff
because it can't be returning a simple string for user.Name
I suspect that it is returning one of the two incarnations that worked in the sample that follows.
If it does, then you just need to modify the split
<SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> a <SPAN class="operator token">=</SPAN> <SPAN class="string token">"somedomain\\xyz\\username1"</SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> b <SPAN class="operator token">=</SPAN> <SPAN class="string token">"somedomain/xyz/username1"</SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> c <SPAN class="operator token">=</SPAN> <SPAN class="string token">"somedomain\xyz\username1"</SPAN> File <SPAN class="string token">"<string>"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">1</SPAN> SyntaxError<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">(</SPAN>unicode error<SPAN class="punctuation token">)</SPAN> <SPAN class="string token">'unicodeescape'</SPAN> codec can't decode bytes <SPAN class="keyword token">in</SPAN> position <SPAN class="number token">10</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">11</SPAN><SPAN class="punctuation token">:</SPAN> truncated \xyz escape <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
It can't just be returning a string with a single backslashes in it eitherwise it would throw and error at some point.
Notice that 'a' and 'b' are fine... either 'raw' format, double backslashes or a single forward slash will pass the test, not a single backslash
a <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"somedomain\\xyz\\username1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"somedomain\\xyz\\username2"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"somedomain\\xyz\\username3"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> emails <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>name<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"\\"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> name <SPAN class="keyword token">in</SPAN> a<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> emails <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'username1'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'username2'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'username3'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
or...
<SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> a <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"somedomain/xyz/username1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"somedomain/xyz/username2"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"somedomain/xyz/username3"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> emails <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>name<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"/"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> name <SPAN class="keyword token">in</SPAN> a<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> emails <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'username1'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'username2'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'username3'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
thanks for the reply...yes that will work but how can I apply it inside the tuple?
Unzipping zips are a pain... so barring the pertinent code snippet... give this a look-see. Note in python the offending string is in 'raw' format, hence the 'r in front of it. A backslash '\' is an escape designator, so to use one without raw format you have to put a double-backslash. Then just split and if the username is the last, just grab the username from the end (-1), if it was the second last, you would use -2 etc
<SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> a <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"somedomain\xyz\username"</SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> b <SPAN class="operator token">=</SPAN> a<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"\\"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> b <SPAN class="string token">'username'</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
