There is not room to put my whole code and it's not in production so I can't share it with you. I have no idea how to navigate well in this new forum, I could barely get logged in, it took multiple tries to get this far, Some things like yearList and rateList are the results of a queryTask, populated earlier in the code. At least you have an idea of some syntax for the axes.
var lineChart = new Chart2D("chartDiv", {
title: chartTitle,
titlePos:"bottom",
titleGap: 12,
titleFont: "normal normal normal 13pt Arial"
lineChart.addPlot("default", {
type: "Lines",
markers: true,
hAxis: "x",
vAxis: "y"});
lineChart.addAxis("x", {
title:"Rates by Year",
titleOrientation:"away",
labels: yearList,
font: "normal normal normal 9pt Arial",
majorLabels: true,
minorTicks: false,
minorLabels: false,
microTicks: false });
lineChart.addAxis("y", {
title:rateNote,
vertical: true,
fixLower: "major",
fixUpper: "major",
min: 0,
max: axisMax,
minorLabels: true});
lineChart.addSeries("Series 1", rateList, {
stroke: { color: "red", width: 2 }
var tip = Tooltip(lineChart, "default", {
text : function(o) {
var yr = yearList[o.x].text;
var yrList = parseInt(yr) - 1;
return ( yrList +'<br>' + o.y );
lineChart.render();
Thanks, Tracy!
I was able to get a line chart to work in my pop-up using dojo charting options.
Now it looks like I'll have to do a querytask as well for multiple rows of data for matching dates to show up for one feature layer.
Mary
The parameters I put in mediaInfos worked to make a piechart. After I switched the chart type to linechart, the linechart showed up but incorrectly placed the line. Without documentation, I'm not sure if there is a certain way to state parameters for the linechart so the data shows up correctly (Ex. x-axis values vs. y-axis values).
On the other hand, dojox charting seems to have additional formatting options which can be useful.
Along with looking at the sources provided, I came across this example using dojox: Info window with chart | ArcGIS API for JavaScript
I'll see what I can do.
Thanks for your help!
