How do I add images stored on a server?
Hi Crystal,
To add images to a story map they must be accessible via a URL and you simply add the URLs of the images to your story map. Specifically how to add the URLs depends on which story map app you are using and where in the story map you want to add an image.
If you could provide a little more info about which app(s) you are using to build your story I can point you in the right direction.
That being said, referencing images where they are currently stored does not optimize them for display in the story map. If you have original, full-resolution images they may be very slow to draw in you story. The best way to add images is to upload them in the story builder so that they live with your story and are optimized to load quickly.
Owen
I created a Feature Layer from Desktop that has a variety of points in it. In AGOL, I added that to a map, shared and then created a story map tour. When the story map opens up, I see all the information for my points. When I try to edit the image and paste the url in there, I can see the picture. Once I save and preview, there are no images at all.
Crystal,
Thanks for the additional information. The issue is likely that since you created the layer yourself it doesn't have the fields required to store image URLs. The feature layer needs fields named "pic_url" and "thumb_url" to store two image links.
Is there a reason you are using Desktop to create the feature layer for your Map Tour? In most cases the best workflow is to build your tour using the Map Tour builder. You can chose to upload images right to your story, which is the best option since your images will be optimized for display on the web, or you can reference the images using their current URLs if they are already on the web.
If you reference images you should make sure you've already optimized them according to the instructions in our FAQ here. To reference images via URLs, choose Advanced options > Start a new tour or download the CSV template if you want to enter all your information at once.
I used Desktop because I already have a feature class with over 100 points that I want to include in the story map. I just thought it would be easier that way.
