import arcpy, sys from xml.etree.ElementTree import ElementTree from arcpy import env env.overwriteOutput = True env.workspace = r"D:\Lakeland_GIS\GDB\Lakeland\Lakeland.gdb\AddPoints" AGSHOME = arcpy.GetInstallInfo("Desktop")["InstallDir"] translatorpath = AGSHOME + r"Metadata\Translator\ARCGIS2FGDC.xml" xmlfile = r"U:\my docs\GIS Projects\Python\Scripts\List Metadata\working_test.xml" # list any standalone feature classes fcList = arcpy.ListFeatureClasses() fcList.sort() for fc in fcList: arcpy.ExportMetadata_conversion(fc, translatorpath, xmlfile) tree = ElementTree() tree.parse(xmlfile) spot = tree.find("idinfo/descript/purpose") print fc print spot.text # list feature datasets datasetList = arcpy.ListDatasets() datasetList.sort() for dataset in datasetList: print dataset # list feature classes inside the dataset fcList = arcpy.ListFeatureClasses("","",dataset) fcList.sort() for fc in fcList: arcpy.ExportMetadata_conversion(fc, translatorpath, xmlfile) tree = ElementTree() tree.parse(xmlfile) spot = tree.find("idinfo/descript/purpose") print " " + fc print " " + spot.text
<?xml version="1.0" ?> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform"> <!-- IdentityTransform --> <xsl:template match="/ | @* | node()"> <xsl:copy> <xsl:apply-templates select="@* | node()" /> </xsl:copy> </xsl:template> </xsl:stylesheet>
According to ESRI documentation:"In geodatabases in Oracle and Informix, the XML columns use ArcSDE XML, which stores information as BLOBs in a series of separate tables. As such, they cannot be directly accessed with SQL."http://resources.arcgis.com/en/help/main/10.2/index.html#/A_quick_tour_of_geodatabase_system_tables/006z000000tr000000/As such, the XML metadata cannot be accessed directly by a simple query to the database. (I tried to hunt for this as you have in the past.)I suggest using a Python script/Model to fully export the metadata.Use the XSLT Transformation tool and with an identity XSLT to extract all the metadata.You can save the code below as a XLST document to feed into the tool.See: http://www.usingxml.com/Transforms/XslIdentity<?xml version="1.0" ?> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform"> <!-- IdentityTransform --> <xsl:template match="/ | @* | node()"> <xsl:copy> <xsl:apply-templates select="@* | node()" /> </xsl:copy> </xsl:template> </xsl:stylesheet>
I want to pass a SQL command, something like Select DOCUMENTATION from gdb_items_vw, to retrieve all the information about the metadata of the layer. But the difficulty is that this DOCUMENTATION field is CLOB type. I found this command that seems correct: SQL> select EXTRACT (XMLType (DOCUMENTATION), '/ metadata') as DOCUMENTATION from sde.gdb_items_vw where name = 'user_name.table_name'; ... but as my sde.gdb_items_vw table is empty, the query gives me 0 selected lines! So why this table is empty? Is that the right table to get metadata?
And some examples are available here in the doc as well. For example:Example: Finding domain owners using SQL
String strLayer = layerName; String connectionURL = null; String connectionID = null; String connectionPW = null; String driverString = null; connectionURL = "jdbc:oracle:thin:@server.domain:port:instance"; connectionID = "username"; connectionPW = "password"; driverString = "oracle.jdbc.driver.OracleDriver"; Class.forName(driverString); sqlconn = java.sql.DriverManager.getConnection(connectionURL, connectionID, connectionPW); stmt = sqlconn.createStatement(); rset = stmt.executeQuery("SELECT uuid, documentation FROM sde.gdb_items_vw where upper(name) = '" + strLayer + "'"); rset.next(); java.io.InputStream xmlStream = rset.getBinaryStream("documentation"); if (xmlStream != null) { URL url1 = new URL(<URL to ArcGIS2FGDC.xsl>); InputStreamReader isr1 = new InputStreamReader(url1.openStream()); StreamSource xslSource1 = new StreamSource(isr1); TransformerFactory tFactory1 = TransformerFactory.newInstance(); Transformer transformer1 = tFactory1.newTransformer(xslSource1); Source schemaSource = new StreamSource(xmlStream); StringWriter writer = new StringWriter(); StreamResult result = new StreamResult(writer); transformer1.transform(schemaSource, result); StringReader reader2 = new StringReader(writer.toString()); writer2 = new StringWriter(); URL url = new URL(<URL to your own xsl>); InputStreamReader isr2 = new InputStreamReader(url.openStream()); StreamSource xslSource = new StreamSource(isr2); TransformerFactory tFactory = TransformerFactory.newInstance(); Transformer transformer2 = tFactory.newTransformer(xslSource); transformer2.transform(new javax.xml.transform.stream.StreamSource(reader2), new javax.xml.transform.stream.StreamResult(writer2)); } xmlStream.close(); rset.close(); sqlconn.close(); return(writer2.toString());
