{ layer: altmaps, slider: true, title: "OS Basemaps", isopen: false }
if (this.data._subLayerInfos) { //acm added to collapse groups at the start this.toggler.hide() //end acm addition
//ACM also changed this line to get groups initial expand set //dojo.addClass(this.iconNode, a ? "dijitTreeExpandoOpened" : "dijitTreeExpandoClosed") dojo.addClass(this.iconNode, a ? "dijitTreeExpandoClosed" : "dijitTreeExpandoClosed")
var toc = new agsjs.dijit.TOC({ map: map, layerInfos: [{ layer: safety, title: "Safety Operations", collapsed: true },{ layer: census, title: "Census", collapsed: true }] }, 'tocDiv'); toc.startup();
Is there any way to have the map service layer initially expanded but all collapsible groups within the map service (unique value renderers and group layers) collapsed?
ok - cracked the code to get all groups collapsed - as in screenshot[ATTACH=CONFIG]18426[/ATTACH]In the postcreate function find and alter as below if (this.data._subLayerInfos) { //acm added to collapse groups at the start this.toggler.hide() //end acm addition and a bit later //ACM also changed this line to get groups initial expand set //dojo.addClass(this.iconNode, a ? "dijitTreeExpandoOpened" : "dijitTreeExpandoClosed") cSo far it appears to work. The second part could be neater, but doing it this way you can see it has been changed to always return "dijitTreeExpandoClosed"ACM
ok - cracked the code to get all groups collapsed - as in screenshot[ATTACH=CONFIG]18426[/ATTACH]In the postcreate function find and alter as below if (this.data._subLayerInfos) { //acm added to collapse groups at the start this.toggler.hide() //end acm addition and a bit later //ACM also changed this line to get groups initial expand set //dojo.addClass(this.iconNode, a ? "dijitTreeExpandoOpened" : "dijitTreeExpandoClosed") dojo.addClass(this.iconNode, a ? "dijitTreeExpandoClosed" : "dijitTreeExpandoClosed") So far it appears to work. The second part could be neater, but doing it this way you can see it has been changed to always return "dijitTreeExpandoClosed"ACM
var show = this.data.visible; // if it is a group layer and no child layer is visible, then collapse if (this.data._subLayerInfos) { var noneVisible = true; dojo.every(this.data._subLayerInfos, function(info) { if (info.visible) { noneVisible = false; return false; } return true; }); if (noneVisible) show = false; } if (this.data.collapsed) show = false; if (this.iconNode && this.iconNode.src == this.blank) { dojo.addClass(this.iconNode, 'dijitTreeExpando'); dojo.addClass(this.iconNode, show ? 'dijitTreeExpandoOpened' : 'dijitTreeExpandoClosed'); } if (this.containerNode) dojo.style(this.containerNode, 'display', show ? 'block' : 'none'); if (this.rootLayerTOC.toc.style == 'standard' && this.iconNode && this.checkNode) { dojo.place(this.iconNode, this.checkNode.domNode || this.checkNode, 'before'); }
TOC widget to not collapse layer Groups when it is turned off?
This method did not work for me!
Use these tags in layerInfo:
collapsed: true,
autoToggle: false
Thanks.
