list = [] # Specify feature class whose features you want to rotate # Append to list to find the Max OBJECTID/FID lstFCs = arcpy.ListFeatureClasses("Parcels") for fc in lstFCs: rows = arcpy.SearchCursor(fc) for row in rows: list.append(row.OBJECTID) del row, rows maxOID = list[-1] x = 1 y = 1 # Loop through each feature, convert to a feature layer, then to raster, rotate raster, convert back to polygon feature class while y <= maxOID: for fc in lstFCs: feat_lay = arcpy.MakeFeatureLayer_management(fc, fc + str(x), "OBJECTID = " + str(x)) ras_lay = arcpy.PolygonToRaster_conversion(feat_lay, "OBJECTID", fc + str(x) + "_ras") # Can improve processing time by specifying a larger cell size feat_lay2 = arcpy.Rotate_management(ras_lay, "ras_rotate" + str(x), 45) arcpy.RasterToPolygon_conversion(feat_lay2, fc + "_rotate_" + str(x)) y = y + 1 x = x + 1 # Print extent of rotated feature classes lstFCs2 = arcpy.ListFeatureClasses("*rotate*") for fc2 in lstFCs2: rows2 = arcpy.SearchCursor(fc2) for row2 in rows2: geom = row2.Shape Extent = geom.extent print Extent del row2, rows2 # Deleted rasters lstRasters = arcpy.ListRasters("*ras*") for raster in lstRasters: arcpy.Delete_management(raster)
