If you decide to register a feature dataset, stand-alone feature class, or table as versioned with the option to move edits to base, right-click it in the Catalog tree, point to Manage, then click Register As Versioned to open the Register As Versioned dialog box. Check Register the selected objects with the option to move edits to base. Checking this option causes edits that have been saved to the DEFAULT version, whether edited directly or merged from other versions, to be saved in the base (business) tables. Edits to other versions remain in the delta tables when you save.
...Versioned views are automatically created for tables or feature classes that are registered as versioned in ArcGIS 10.1 or later releases.....
