Eddie:Are you publishing the maps to server 10.1 on the same machine where server is installed?If so, is your data stored in an Oracle SDE database?This is my current setup and I had to install both 32 and 64 bit Oracle Client software in order to register the data stores correctly and not have the SDE data automatically copied to the ArcGIS Server server.I don't know if this will help, but at least you can rule it out if it does not apply.
same error message for me too.
ArcGIS Server Manager (above) is on another machine 'gis3' than the data I'm trying to register which is on 'gis2'.
Share the folder in "GIS2" with everyone (from Windows Explorer). Define the shared path (It will start with "\\") in Publisher folder path.
I don't have admin rights to share the GIS2 folder with everyone in the company.
Only a few people can access the GIS2 drive, but I want everyone to be able to view in an online format, the GIS data (shapefiles) stored within the GIS2 drive.
Make sure the ArcGIS Server admin account has access to the folders in question.
thanks Rebecca. However, being a novice to this, I don't know how to do that.
