Try to export as a GeoPDF.In ArcMap: File -> Export map -> select .pdf as output. In Advanced tab choose Export PDF Layers and Feature Attributes. Before exporting remove all unnecesary fields and layers from layout.In Adobe Reader turn on Model Tree navigation pane on the left side, right click on the page and choose Object Data Tool. Then click several times on your point until only one point is selected. In Model Tree you would see its attributes.On the Layers navigation pane you can turn off some layers to increase performance.Beware that performance of PDF with many layers and attributes may be low.
In Adobe Reader turn on Model Tree navigation pane on the left side, right click on the page and choose Object Data Tool. Then click several times on your point until only one point is selected. In Model Tree you would see it's attributes.
