<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"> <fx:Script> <![CDATA[ import com.esri.ags.utils.JSONUtil; import mx.controls.Alert; import mx.utils.ObjectUtil; private var fileReference:FileReference; private var timer:Timer; private var baseTimer:int; private function onLoad():void { //Instantiate on loading fileReference = new FileReference(); //create the filter which will be just uploading the txt var myFilter:FileFilter = new FileFilter("Zip", "*.zip"); fileReference.browse([ myFilter ]); fileReference.addEventListener(Event.SELECT, onFileSelect); fileReference.addEventListener(Event.COMPLETE, onFileComplete); fileReference.addEventListener(DataEvent.UPLOAD_COMPLETE_DATA, onUploadCompleteData); timer = new Timer(1000); timeElapsed.visible = timeElapsed.includeInLayout = true; timer.addEventListener(TimerEvent.TIMER, updateTimer); } private function onFileSelect(event:Event):void { var fileUploadRequest:URLRequest = new URLRequest("http://server/arcgis/rest/services/ServiceName/GPServer/uploads/upload"); fileUploadRequest.method = URLRequestMethod.POST; var urlVars:URLVariables = new URLVariables(); urlVars.f = "json"; urlVars.description = "this is just a test upload"; fileUploadRequest.data = urlVars; fileReference.upload(fileUploadRequest, "file"); baseTimer = getTimer(); timeElapsed.visible = timeElapsed.includeInLayout = true; timer.start(); } private function onFileComplete(event:Event):void { timer.stop(); timeElapsed.visible = timeElapsed.includeInLayout = false; } private function updateTimer(event:TimerEvent):void { timeElapsed.text = "TimeElapsed: " + new Date(getTimer() - baseTimer).seconds + "secs"; } private function onUploadCompleteData(event:DataEvent):void { var result:Object = JSONUtil.decode(event.data); Alert.show(ObjectUtil.toString(result), "upload completed - " + result.item.itemID); } ]]> </fx:Script> <s:Panel id="myPanel" width="500" height="500"> <s:VGroup> <s:Button click="onLoad()" label="Upload"/> <s:Label id="timeElapsed" includeInLayout="false" visible="false"/> </s:VGroup> </s:Panel> </s:Application>
Is there supposed to be an uploads capability as part of the geoprocessor class? The REST enpoint exposes this functionality, but I can't find this capability within the API. Am I missing something?
