protected function init():void { var query:com.esri.ags.tasks.supportClasses.Query = new com.esri.ags.tasks.supportClasses.Query(); query.outFields = [ "NAME_1" ]; query.outSpatialReference = map.spatialReference; query.returnGeometry = true; query.where = "1=1"; queryTask.execute(query); }
import com.esri.ags.tasks.supportClasses.Query;
<?xml version="1.0" encoding="utf-8"?> <!-- //////////////////////////////////////////////////////////////////////////////// // // Copyright (c) 2010 ESRI // // All rights reserved under the copyright laws of the United States. // You may freely redistribute and use this software, with or // without modification, provided you include the original copyright // and use restrictions. See use restrictions in the file: // <install location>/License.txt // //////////////////////////////////////////////////////////////////////////////// --> <viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" xmlns:custom="components.*" xmlns:viewer="com.esri.viewer.*" widgetConfigLoaded="init()"> <fx:Declarations> <esri:QueryTask id="queryTask" executeComplete="queryTask_executeCompleteHandler(event)" showBusyCursor="true" url="http://167.193.56.180/ArcGIS/rest/services/Georgia_Beach/MapServer/0" useAMF="false"/> </fx:Declarations> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.events.MapEvent; import com.esri.ags.events.QueryEvent; import com.esri.ags.geometry.Extent; import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import com.esri.ags.tasks.supportClasses.Query; import com.esri.ags.utils.GraphicUtil; import mx.collections.ArrayCollection; import mx.collections.ArrayList; import spark.events.IndexChangeEvent; protected function init():void { var query:Query = new Query(); query.outFields = [ "NAME_1" ]; query.outSpatialReference = map.spatialReference; query.returnGeometry = true; query.where = "1=1"; queryTask.execute(query); } protected function queryTask_executeCompleteHandler(event:QueryEvent):void { ddList.dataProvider = new ArrayList(event.featureSet.features); } protected function ddListLabelFunction(item:Graphic):String { return item.attributes["NAME_1"]; } protected function ddList_changeHandler(event:IndexChangeEvent):void { var pt:MapPoint = MapPoint(Graphic(ddList.selectedItem).geometry); var beachExtent:Extent = new Extent(pt.x - 100, pt.y -100, pt.x + 100, pt.y + 100); map.extent = beachExtent // make sure the whole extent is visible if (!map.extent.contains(beachExtent)) { map.level--; } } ]]> </fx:Script> <viewer:WidgetTemplate id="DropDown" width="300" height="200" > <viewer:layout> <s:HorizontalLayout horizontalAlign="center" verticalAlign="middle"/> </viewer:layout> <s:DropDownList id="ddList" width="200" change="ddList_changeHandler(event)" labelFunction="ddListLabelFunction" prompt="Choose a beach..."/> </viewer:WidgetTemplate> </viewer:BaseWidget>
