If you display both layers in ArcMap, do they overlay each other as they are supposed to? If not you still have projection problems.Also, you are using the polyline layer as the input layer and the polygon layer as the clip layer right? If yes to both of those I would probably try running the Check Geometry on the problem layer and if there are problems run Repair Geometry and then try again.
