# FrequencyWithCase.py # do it properly ESRI # 19 May 2010 # add a case item to the source table # like Workstation import arcgisscripting,sys,os try : table = sys.argv[1] strFields = sys.argv[2] except : table = "e:/data/nzpost/paf2010/geopaf.gdb/pafpost" strFields = "postcode;postcode_1" gp = arcgisscripting.create(9.3) casefld = "case" ws = os.path.dirname(table) tabname = os.path.basename(table) gp.Workspace = ws if len(gp.Listfields(table,casefld)) == 0 : result = gp.AddField(table,casefld,"LONG") print result.GetOutput(0) else : # name = gp.AddField(table,"case1","LONG") print casefld,"Exists" if gp.ListFields(table,casefld) == None : raise Exception,"no case field" seqfld = 'sequence' if len(gp.Listfields(table,seqfld)) == 0 : result = gp.AddField(table,seqfld,"LONG") print result.GetOutput(0) else : # name = gp.AddField(table,"case1","LONG") print seqfld,"Exists" if gp.ListFields(table,seqfld) == None : raise Exception,"no sequence field" # make a dictionary with a combo key # populate the source table as we go # export the dictionary at the end # make a tuple of all fields # check if its in dictionary # if it is increment counter # otherwise add new entry # retrieve number # put number into index or back on table # dFreq = {} lstFields = strFields.split(";") print lstFields cur = gp.UpdateCursor(table) row = cur.next() n = 0 ccase = 0 while row: combo = [] for f in lstFields : combo.append( row.GetValue(f) ) combo = tuple(combo) if dFreq.has_key(combo) : thiscase,freq = dFreq[combo] dFreq[combo] = (thiscase,freq+1) row.case = thiscase row.sequence = freq+1 else : ccase+=1 dFreq[combo] = (ccase,1) row.case = ccase row.sequence = 1 cur.UpdateRow(row) ## if n > 1000 : ## break n+=1 row = cur.next() del cur,row print print "case freq" keytab = dFreq.values() keytab.sort() ##for x in keytab: ## print "%4d %4d" % x print len(dFreq),"cases" # write out frequency table with case item fTab = tabname+"Freq" if gp.Exists(fTab) : gp.Delete(fTab) gp.CreateTable(ws,fTab) gp.AddField(fTab,casefld,"LONG") gp.AddField(fTab,"Frequency","LONG") dscTable = gp.Describe(table) dType = {"String":"TEXT","Integer":"LONG"} for f in lstFields: fType = dType[gp.ListFields(table,f)[0].type] gp.AddField(fTab,f,fType) # may not be a "long" in general case print f,"added to",fTab cur = gp.InsertCursor(fTab) for k in dFreq.keys(): ## print dFreq[0],dFreq[1],dFreq row = cur.NewRow() row.case = dFreq[0] row.Frequency = dFreq[1] n = 0 for i in k: ##print i,n,lstFields fld = lstFields row.SetValue(fld, i) n+=1 cur.InsertRow(row) del cur,row print "Done"
Use the SummaryStatistics tool: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00080000001z000000.htmIt does everything that Frequecy does and more...
Does anyone know why the case_item field was eliminated from the frequency tool in ArcGIS Desktop? In ArcInfo Workstation the option to add a case_item made it very easy to join the frequency table to the feature table. This question was initially asked in 2007 (http://forums.esri.com/thread.asp?c=93&f=1729&t=233587), but did not get a response.
