public class MouseCoordinatesAction : TriggerAction<Map> { /// <summary> /// Invokes the action. /// Search for the user provided address /// </summary> /// <param name="parameter">The parameter to the action. If the Action does not require a parameter, the parameter may be set to a null reference.</param> protected override void Invoke(object parameter) { Messenger.Default.Send(GetCoordinateString(parameter as MouseEventArgs), "FromMainViewModel"); } private string GetCoordinateString(MouseEventArgs e) { //this is the body of the method, but I will remove it to make the code shorter return mouseCoordString; } } //**************************** Inside MainViewModel ************************* //A string with the current mouse point coordinates private string _currentMapPoint; /// <summary> /// A string with the current mouse point coordinates /// </summary> public string CurrentMapPoint { get { return _currentMapPoint; } set { if (_currentMapPoint != value) { _currentMapPoint = value; OnNotifyPropertyChanged("CurrentMapPoint"); } } } public MainViewModel() { //requires a reference to GalaSoft.MvvmLight.SL4 Messenger.Default.Register<string>(this, "FromMainViewModel", (e => this.CurrentMapPoint = e)); } //********************** In MainView xaml - Trigger is inside the Map control*********************** <i:Interaction.Triggers> <i:EventTrigger EventName="MouseMove"> <actions:MouseCoordinatesAction /> </i:EventTrigger> </i:Interaction.Triggers> <TextBlock Text="{Binding CurrentMapPoint}" x:Name="mouseCoordinates" Width="200" Height="22" VerticalAlignment="Bottom" HorizontalAlignment="Right"/>
public class MouseCoordinatesAction : TargetedTriggerAction<MainViewModel> { /// <summary> /// Invokes the action. /// Search for the user provided address /// </summary> /// <param name="parameter">The parameter to the action. If the Action does not require a parameter, the parameter may be set to a null reference.</param> protected override void Invoke(object parameter) { Target.CurrentMapPoint = GetCoordinateString(parameter as MouseEventArgs); } private string GetCoordinateString(MouseEventArgs e) { //removing the body for shortness return mouseCoordString; } } //**************************** Inside MainViewModel ************************* //A string with the current mouse point coordinates private string _currentMapPoint; /// <summary> /// A string with the current mouse point coordinates /// </summary> public string CurrentMapPoint { get { return _currentMapPoint; } set { if (_currentMapPoint != value) { _currentMapPoint = value; OnNotifyPropertyChanged("CurrentMapPoint"); } } } //********************** In MainView xaml - Trigger is inside the Map control*********************** <i:Interaction.Triggers> <i:EventTrigger EventName="MouseMove"> <actions:MouseCoordinatesAction TargetObject="{Binding DataContext, ElementName=LayoutRoot}" /> </i:EventTrigger> </i:Interaction.Triggers> <TextBlock Text="{Binding CurrentMapPoint}" x:Name="mouseCoordinates" Width="200" Height="22" VerticalAlignment="Bottom" HorizontalAlignment="Right"/>
public class MouseCoordinatesAction : TriggerAction<Map> { /// <summary> /// Invokes the action. /// Search for the user provided address /// </summary> /// <param name="parameter">The parameter to the action. If the Action does not require a parameter, the parameter may be set to a null reference.</param> protected override void Invoke(object parameter) { MousePoint = GetCoordinateString(parameter as MouseEventArgs); } private string GetCoordinateString(MouseEventArgs e) { //removing code for shortness return mouseCoordString; } /// <summary> /// The symbol used to display the addresss point buffer on the map /// </summary> public string MousePoint { get { return (string)GetValue(MousePointProperty); } set { SetValue(MousePointProperty, value); } } public static readonly DependencyProperty MousePointProperty = DependencyProperty.Register("MousePoint", typeof(string), typeof(MouseCoordinatesAction), null); } //**************************** Inside MainViewModel ************************* //A string with the current mouse point coordinates private string _currentMapPoint; /// <summary> /// A string with the current mouse point coordinates /// </summary> public string CurrentMapPoint { get { return _currentMapPoint; } set { if (_currentMapPoint != value) { _currentMapPoint = value; OnNotifyPropertyChanged("CurrentMapPoint"); } } } //********************** In MainView xaml - Trigger is inside the Map control*********************** <i:Interaction.Triggers> <i:EventTrigger EventName="MouseMove"> <actions:MouseCoordinatesAction MousePoint="{Binding CurrentMapPoint,Mode=TwoWay" /> </i:EventTrigger> </i:Interaction.Triggers> <TextBlock Text="{Binding CurrentMapPoint}" x:Name="mouseCoordinates" Width="200" Height="22" VerticalAlignment="Bottom" HorizontalAlignment="Right"/>
<UserControl x:Class="MVVM_Debug.MainPage" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:interactivity="http://schemas.microsoft.com/expression/2010/interactivity" xmlns:interactions="http://schemas.microsoft.com/expression/2010/interactions" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:esri="http://schemas.esri.com/arcgis/client/2009" xmlns:command="clr-namespace:GalaSoft.MvvmLight.Command;assembly=GalaSoft.MvvmLight.Extras.SL4" xmlns:actions="clr-namespace:MVVM_Debug.Actions" xmlns:behaviors="clr-namespace:MVVM_Debug.Behaviors" xmlns:controls="clr-namespace:MVVM_Debug.Controls" xmlns:helpers="clr-namespace:MVVM_Debug.Helpers" xmlns:toolkit="clr-namespace:MVVM_Debug.Toolkit" mc:Ignorable="d" d:DesignHeight="600" d:DesignWidth="800" DataContext="{Binding Main, Source={StaticResource Locator}}"> <UserControl.Resources> <ResourceDictionary> <ResourceDictionary.MergedDictionaries> <ResourceDictionary Source="Skins/MainSkin.xaml"/> </ResourceDictionary.MergedDictionaries> </ResourceDictionary> </UserControl.Resources> <Grid x:Name="LayoutRoot"> <esri:Map x:Name="map_BaseMap" Layers="{Binding Path=MapLayers}" helpers:MapHelper.ZoomGeometry="{Binding Path=MapExtent}" MinimumResolution=".25"> <esri:Map.Extent> <esri:Envelope XMin="-10510990.377700" YMin="5586273.272800" XMax="-10364472.557100" YMax="5682307.505400"> <esri:Envelope.SpatialReference> <esri:SpatialReference WKID="102100"/> </esri:Envelope.SpatialReference> </esri:Envelope> </esri:Map.Extent> <interactivity:Interaction.Triggers> <interactivity:EventTrigger EventName="MouseMove"> <actions:MouseCoordinateAction TargetObject="{Binding Path=DataContext, ElementName=LayoutRoot}" PropertyName="{Binding Path=Coordinates}"/> </interactivity:EventTrigger> </interactivity:Interaction.Triggers> </esri:Map> <controls:LogisNavigation Margin="5" Map="{Binding ElementName=map_BaseMap}" FullExtentGeometry="{Binding Path=FullExtent}" InitialExtentGeometry="{Binding Path=InitialExtent}" helpers:NavigationHelper.ZoomReset="{Binding Path=MapExtent}" Background="Gray" BorderBrush="White" Foreground="Black"/> <esri:MapProgressBar HorizontalAlignment="Center" VerticalAlignment="Bottom" Margin="0,0,0,5" Width="150" Map="{Binding ElementName=map_BaseMap}"/> <controls:LogisScaleBar HorizontalAlignment="Left" VerticalAlignment="Bottom" Margin="5" Width="200" MapUnit="Meters" Map="{Binding ElementName=map_BaseMap}"/> <TextBlock HorizontalAlignment="Center" VerticalAlignment="Top" Margin="5" Foreground="White" Text="{Binding Path=Coordinates.X, StringFormat=\{0:F4\}}"/> </Grid> </UserControl>
using System.Windows; using System.Windows.Input; using ESRI.ArcGIS.Client; using ESRI.ArcGIS.Client.Geometry; using ESRI.ArcGIS.Client.Projection; using Microsoft.Expression.Interactivity.Core; namespace MVVM_Debug.Actions { public class MouseCoordinateAction : ChangePropertyAction { protected override void Invoke(object parameter) { this.Value = GetLatLon(parameter as MouseEventArgs); base.Invoke(parameter); } private MapPoint GetLatLon(MouseEventArgs e) { Map map = AssociatedObject as Map; Point mouseLoc = e.GetPosition(map); MapPoint coordLoc = map.ScreenToMap(mouseLoc); if (coordLoc != null && coordLoc.Extent.SpatialReference.WKID == 102100) { WebMercator webMercator = new WebMercator(); MapPoint latLon = webMercator.ToGeographic(coordLoc) as MapPoint; return latLon; } else return null; } } }
using System.Windows; using System.Windows.Input; using ESRI.ArcGIS.Client; using ESRI.ArcGIS.Client.Geometry; using ESRI.ArcGIS.Client.Projection; using Microsoft.Expression.Interactivity.Core; public class CoordinateChangePropertyAction : ChangePropertyAction { protected override void Invoke(object parameter) { this.Value = GetCoordinateString(parameter as MouseEventArgs); base.Invoke(parameter); } private string GetCoordinateString(MouseEventArgs e) { string mouseCoordString = string.Empty; Map map = AssociatedObject as Map; Point mouseLoc = e.GetPosition(map); MapPoint coordLoc = map.ScreenToMap(mouseLoc); if (coordLoc != null) { WebMercator webMercator = new WebMercator(); MapPoint latLon = webMercator.ToGeographic(coordLoc) as MapPoint; mouseCoordString = string.Format("Lon {0:F4}° Lat {1:F4}°", latLon.X, latLon.Y); } return mouseCoordString; } }
<esri:Map x:Name="map_BaseMap"> <i:Interaction.Triggers> <i:EventTrigger EventName="MouseMove"> <MyActionNamespace:CoordinateChangePropertyAction TargetObject="{Binding DataContext, ElementName=LayoutRoot}" PropertyName="SomePropertyOnTheViewModelToBindTo"/> </i:EventTrigger> </i:Interaction.Triggers> </esri:Map>
public class MouseCoordinatesAction :TargetedTriggerAction<TextBlock> { /// <summary> /// Invokes the action. /// Search for the user provided address /// </summary> /// <param name="parameter">The parameter to the action. If the Action does not require a parameter, the parameter may be set to a null reference.</param> protected override void Invoke(object parameter) { if ((Target != null) && (parameter != null)) Target.Text = GetCoordinateString(parameter as MouseEventArgs); } private string GetCoordinateString(MouseEventArgs e) { string mouseCoordString = string.Empty; Map map = AssociatedObject as Map; Point mouseLoc = e.GetPosition(map); MapPoint coordLoc = map.ScreenToMap(mouseLoc); if (coordLoc != null) { WebMercator webMercator = new WebMercator(); MapPoint latLon = webMercator.ToGeographic(coordLoc) as MapPoint; mouseCoordString = string.Format("Lon {0:F4}° Lat {1:F4}°", latLon.X, latLon.Y); } return mouseCoordString; } }
<Grid x:Name="LayoutRoot"> <esri:Map x:Name="map_BaseMap" Layers="{Binding Path=MapLayers}" helpers:MapHelper.ZoomGeometry="{Binding Path=MapExtent}" MinimumResolution=".25"> <esri:Map.Extent> <esri:Envelope XMin="-10510990.377700" YMin="5586273.272800" XMax="-10364472.557100" YMax="5682307.505400"> <esri:Envelope.SpatialReference> <esri:SpatialReference WKID="102100"/> </esri:Envelope.SpatialReference> </esri:Envelope> </esri:Map.Extent> <interactivity:Interaction.Triggers> <interaction:EventTrigger EventName="MouseMove"> <actions:MouseCoordinatesAction TargetName="mouseCoordinates" /> </i:EventTrigger> </esri:Map> <controls:LogisNavigation Margin="5" Map="{Binding ElementName=map_BaseMap}" FullExtentGeometry="{Binding Path=FullExtent}" InitialExtentGeometry="{Binding Path=InitialExtent}" helpers:NavigationHelper.ZoomReset="{Binding Path=MapExtent}" Background="Gray" BorderBrush="White" Foreground="Black"/> <esri:MapProgressBar HorizontalAlignment="Center" VerticalAlignment="Bottom" Margin="0,0,0,5" Width="150" Map="{Binding ElementName=map_BaseMap}"/> <controls:LogisScaleBar HorizontalAlignment="Left" VerticalAlignment="Bottom" Margin="5" Width="200" MapUnit="Meters" Map="{Binding ElementName=map_BaseMap}"/> <TextBlock x:Name="mouseCoordinates" HorizontalAlignment="Center" VerticalAlignment="Top" Margin="5" Foreground="White"/> </Grid>
<Grid x:Name="LayoutRoot"> <esri:Map x:Name="map_BaseMap" Layers="{Binding Path=MapLayers}" helpers:MapHelper.ZoomGeometry="{Binding Path=MapExtent}" MinimumResolution=".25"> <esri:Map.Extent> <esri:Envelope XMin="-10510990.377700" YMin="5586273.272800" XMax="-10364472.557100" YMax="5682307.505400"> <esri:Envelope.SpatialReference> <esri:SpatialReference WKID="102100"/> </esri:Envelope.SpatialReference> </esri:Envelope> </esri:Map.Extent> <interactivity:Interaction.Behaviors> <behaviors:MouseCoordinateBehavior/> </interactivity:Interaction.Behaviors> </esri:Map> <controls:LogisNavigation Margin="5" Map="{Binding ElementName=map_BaseMap}" FullExtentGeometry="{Binding Path=FullExtent}" InitialExtentGeometry="{Binding Path=InitialExtent}" helpers:NavigationHelper.ZoomReset="{Binding Path=MapExtent}" Background="Gray" BorderBrush="White" Foreground="Black"/> <esri:MapProgressBar HorizontalAlignment="Center" VerticalAlignment="Bottom" Margin="0,0,0,5" Width="150" Map="{Binding ElementName=map_BaseMap}"/> <controls:LogisScaleBar HorizontalAlignment="Left" VerticalAlignment="Bottom" Margin="5" Width="200" MapUnit="Meters" Map="{Binding ElementName=map_BaseMap}"/> <TextBlock HorizontalAlignment="Center" VerticalAlignment="Top" Margin="5" Foreground="White"/> </Grid>
using System.Windows; using System.Windows.Input; using System.Windows.Interactivity; using ESRI.ArcGIS.Client; using ESRI.ArcGIS.Client.Geometry; using ESRI.ArcGIS.Client.Projection; namespace MVVM_Debug.Behaviors { public class MouseCoordinateBehavior : Behavior<Map> { #region Constructors public MouseCoordinateBehavior() : base() { } #endregion #region Properties public string MouseCoordinates { get; private set; } #endregion #region Methods protected override void OnAttached() { base.OnAttached(); this.AssociatedObject.MouseMove += new MouseEventHandler(AssociatedObject_MouseMove); } protected override void OnDetaching() { base.OnDetaching(); this.AssociatedObject.MouseMove -= new MouseEventHandler(AssociatedObject_MouseMove); } void AssociatedObject_MouseMove(object sender, MouseEventArgs e) { Map map = (Map)sender; Point mouseLoc = e.GetPosition(map); MapPoint coordLoc = map.ScreenToMap(mouseLoc); if (coordLoc != null) { WebMercator webMercator = new WebMercator(); MapPoint latLon = webMercator.ToGeographic(coordLoc) as MapPoint; MouseCoordinates = string.Format("Lon {0:F4}° Lat {1:F4}°", latLon.X, latLon.Y); } } #endregion } }
