Hi Etienne:
I'm having the same issue as the one you're describing (in fact the bottom-right window corner is also buggy on my Export Map dialog box and the "Write to Word" option is greyed out as in your screenshot). I work remotely using VirtualBox lots of the time on my MacBook (which could be the cause of many problems from the start), and it'd be beneficial to fix this bug. When I use the university computers, I also don't experience the issue.
I agree that it is a screen issue that arises when ArcMap communicates with Windows. Do you know of any solutions? I'd even take an arcpy workaround, if there are any (since the Clip to Graphic Extent isn't available with the arcpy.mapping module, ugh!).
Thanks for your time!
Sam
Etienne:
I fixed the problem for my case, it was just a matter of putting VirtualBox in full screen mode! It's definitely got something to do with the extent that you initially give ArcMap to display the dialog box. Giving it too little room will always clip the window. Apologies for not being able to fix the initial bug. I guess it's best to expand ArcMap as much as it can before launching the window.
Hi All,
PLEASE HELP! I am having this issue as well and being an ArcGIS newby and would appreciate any assistance in simplified terms - ie. I have no idea what VirtualBox is! Thanks in advance.
Regards,
Jane
Jane:
Virtualbox is software to virtualize a Windows environment on a Mac.
From the various solution, it sounds like this is related to screen resolution, maximized views, etc...
Folks can help you better if you provide more info: what version of ArcMap? Are you on a Win PC or a Mac? Desktop or laptop? screen resolution, graphics card etc might come into play.
Because of that, this sounds like a problem possibly best handled 1:1 with Esri support. They can share your screen and get into the weeds with you.
Good luck
Hi! I've got the similar issue. The option 'Clip Output to Graphic Extent' has disappeared after some manipulations with Export dialog window size. I'm running ArcGIS for Desktop 10.4 under Windows 10 on a laptop with 1366*768 screen resolution.
Any ideas? Thank you in advance!
P.S. the problem gets solved when enable 'Auto-hide the taskbar' in Windows, but returns back on disabling this option...
Lost the "Clip Output to Graphics Extent" too. Tried the many suggestions. Rename Normal.mxt and re-start, checked the Exportdlg setting in Regedit, enabled the "Auto-hide the taskbar" in Windows, tab-tab-tab-tab-space bar. Still don't have the clip option. Running Desktop 10.6.1 in Win10. Clip the white board in Paint has been my solution for images. Any additional fixes? Thanks, Greg
