Anyone know when Web AppBuilder (Developer Edition) 1.2 is going to be released? I thought it was scheduled to be released the first week of August 2015, but apparently the date has been pushed back.
Josh
FYI Josh,
Web AppBuilder for ArcGIS v1.2 Developer Edition is now available for download:
https://developers.arcgis.com/web-appbuilder/
Enjoy!
Joshua,
I think the official statement was early August.
Okay, I guess that means sometime before August 15th? I was told it would be released the first week in August at the International User Conference. Also referencing this post: Re: When can we expect the July release of Developer Edition WAB?
Yep looks like they are going to miss that week.
And that post was before the UC. I remember hearing early August at the UC...which technically should be by the 15th, but from past experience, a planned target date may shift a bit if they aren't quite ready. I'm sure it's close.
New blog post posted August 10, 2015
Web AppBuilder for ArcGIS v1.2 Developer Edition Available This Week! | ArcGIS Blog
expected release later this week....so pretty much as announced at the UC.
Hi Rebecca - I'm sure this answer is posted somewhere but thus far have been unable to locate it. I didn't get started with WAB unit 1.1 so I'm wondering if you know how I go about updating my current 1.1 developer edtion to 1.2 upon it's release? Is it treated as a new install / workspace where I then migrate in any customizations?
Thanks-
David
David,
See this link for upgrading apps:
Upgrade apps—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Thanks Robert, that's it. I must of had a blindspot
Hi Derek, Has this BUG-000087830 – Web AppBuilder for ArcGIS Developers Edition does not allow anonymous access to an application when Portal for ArcGIS is configured with Integrated Windows Authentication (IWA). The web maps configured with the application are shared with everyone in Portal for ArcGIS – fixed in this edition?
Hi SR,
BUG-000087830 was rejected because this is how the software was designed to work.
When Portal for ArcGIS is configured with Integrated Windows Authentication (IWA), by definition Portal does NOT allow for anonymous access. You must be a member of the Windows Active Directory and provide explicit credentials to access Portal, therefore we can't allow anonymous access to a web app.
Hope this helps,
Derek:
When Portal is configured with IWA, does the concept of publishing for "Everyone" have any meaning?
Does a map published for Everyone mean that any WIA authenticated user can see the map, even if they are not a Named User?
Or does configuring Portal with IWA mean that an IWA domain authenticated user must also be a Named User to access any information via Portal?
