Hello, I am facing some difficulties with the projection trasform from ETRS89 / ETRS-LAEA to UTM33WGS84.There is anybody which has the same problem, or someone who can help me,please?thank you Anna
Same here: ArcGIS does not project correctly between ETRS-LAEA and WGS84ArcGIS Desktop (ArcView) 9.3.1 SP1, on Windows VistaTo verify the problem:go to http://www.eea.europa.eu/data-and-maps/data/urban-atlas and download the file it010l_catania.zip. This covers the town of Catania in Sicily, Italy, at aprox. 15.1E / 37.5NThe data comes in an Lambert Azimuthal Equal Area projection on ETRS89.I project this into WGS84, using the ArcGIS project tool. The process succeeds without error or warnings. However, the result lies at about 4.2E / 14.4S. This is definitely wrong.I also project the dataset into WGS84, using QuantumGIS. The result lies at about 15.1E / 37.5N. This is correct.I submitted this as a support case to our local distributor, ESRI UK. Will post solution.
Hello,Thank you very much for providing a link to some data. The minute I looked at the .prj file I was able to figure out what was happening. The .prj file is using these projection parameters:latitude_of_centerlongitude_of_centerESRI software expectslatitude_of_origincentral_meridianThe "center" parameters aren't recognized as corresponding to latitude of origin and central meridian, so internally these two parameters have values of 0,0. That's why the longitude values are around 4E and the latitude values are around 14S.I've attached a .prj file (renamed .txt so it can be uploaded) with the ESRI version of ETRS-LAEA. Please redefine the data with that coordinate system, and I think you will find it working much better.Another issue is that we use different names in the ETRS 1989 definition which triggers "these are not the same".I hope this is useful,Melita
Check the file permissions of the data using the normal windows file explorer.Either the data itself or the directory it is in is probably set to "read only".Good luck,Neil
Hello!
The discussion is quite old but i have a similar problem. I try to project from WGS_1984 to ETRS_1989 but i always get error "000365 : Invalid geographic transformatin" and error 000361.
Can someone give me a hint? Thank you!
Hi Sophi,
That often means that we don't recognize the coordinate system (spatial reference) of the input data. For instance, there a different name or a value is not quite the same. Try redefining the coordinate system using the Define Projection Tool or the data's property page in ArcCatalog.
Could also occur if you're not directly using the coordinate systems folder to pick the output coordinate system but importing it from other data or a file.
Melita
